Car status indicator
The panel in the dash what tells you if a doors open and stuff works intermittently also the low fuel light and the other light all stop at the same time, Its driving me mad trying to find the problem anyone got any ideas?
OCD Victim
Re: Car status indicator
Originally Posted by marcus264
Will give it a look this evening, put the gauges on hold
At least I will know when the boot is not shut. cheers all
{sorry, couldn't resist}
Seriously, it is more than likely the AWS connector plug, or less likely, the module itself. Clean it or replace the unit as you see fit.
More boost Igor!
Originally Posted by Sideways_Sierra
or just ignore it, i do with mine, keeps saying the passenger rear door is open , ..... bollox
Resident Wrestling Legend
the aws units are in some strange places inside the lower dash on all the cars i've taken them out of, sometimes they are behind one of the kick panels and in the laster cars they are behind the drivers side glovebox and behind the passenger side top cubby hole
you'd need to know exactly where they were before starting to take the dash apart to look for a fix
Stu @ M Developments
41
21-08-2015 06:47 AM
RIB1122
12-08-2015 08:51 PM
