Missfire ???
Missfire ???
2wd sierra cosworth stage 1
I was out a few nights ago and was having alittle play on the motorway after slowing down coming off the car has developed some sort of missfire well i think its that it does it when its idling and when you drive there is hardly any power even when turbo comes on ?
What are the things it could be
Plugs ?
Leads?
fucked Turbo ?
Blown headgasket ?
where do i start
Plugs ?
Leads?
fucked Turbo ?
Blown headgasket ?
where do i start
I tryed that.. EXACTLY that, 2 times in a row, right after I have fixed my headgasket I was scared to death. Both times it was the distributorcap centrepole that have died (brand new ones both times). The car drove on some point ok but powerless especially if I accelerated normally, and when idle there was a little misfire when listening carefully. I understood why when I checked all the basics... the car drove on the dis.cap centerpole spring!!!
Think the first cap was fitted a little to fast second one must have been a bad one.
i had the same thing happen on my 2wd saff blew a plug tip off turned
out the injectors were about had it so had them cleaned an tested
what ever they do lucky escape there hope this helps
Ginge !
23
28-05-2005 01:06 PM
