Focus RS mk1 Aftermarket Water Temp Gauge
Old 21-08-2013, 01:29 PM
RS Bowk
RS Bowk's Avatar
Default Focus RS mk1 Aftermarket Water Temp Gauge
What have you guys done? Ive got a mate who is not happy with there not being a water temp gauge in his focus as standard.
Anybody got any pics of alternatives to standard?
Old 21-08-2013, 01:33 PM
SBT83
Not Crazy, just Unwell
SBT83's Avatar
Sorry bout the small pics (iPhone)
Put something like this in line, and a sender screws in the top
Old 21-08-2013, 01:36 PM
RS Bowk
RS Bowk's Avatar
Im interested to see what you guys have done inside the car.
Old 21-08-2013, 02:02 PM
JamboRS
focus rs 1672
JamboRS's Avatar
could go for a scangauge like this
ive got the plx devices gauge which reads water and charge temps from obd and has the afr module
Old 21-08-2013, 09:07 PM
Shings
Shings's Avatar
Don't have one. 18k miles in the 18 months, between 60 and 600 miles a week depending on where I'm working. No problems.
Old 22-08-2013, 12:57 PM
RS Bowk
RS Bowk's Avatar
Any others?
Old 22-08-2013, 04:38 PM
RSargie
RSargie's Avatar
Being a more modern ford, it has a fail safe cooling system. Where when the engine management detects an over heating issue. It illuminates a warning light. Engages limp mode and will only let you drive for a limited time. Then the engine will shut Down to save a failure.
Much more important for this type of car is inlet charge air temp because there is no fail safe for increased inlet temp . I.e charge cooler pump failure. Which can cause detonation .
Old 22-08-2013, 05:09 PM
GVK.
GVK.'s Avatar
Scangauge idea is the best, there's a German site that sells something similar too which is configurable for any parameters from the OBD socket.
http://www.obd2-shop.eu/ultragaugeemv12-p-287.html
Old 22-08-2013, 09:37 PM
rhys78
rhys78's Avatar
first thing i bought for both my RS's was a scanguage. better to be safe than sorry
Old 10-09-2013, 04:46 PM
Simmo
Simmo's Avatar
I've got one of these plumbed into the top hose and a Scangauge too, would say the Scangauge is good enough on its own but the gauge was on the car when I bought it
gavt123
05-09-2015 10:03 AM
Fordmad!
04-09-2015 01:42 PM
Ben26
03-09-2015 07:55 PM
CrOwSoN15
14
03-09-2015 12:21 PM
03-09-2015 10:49 AM
Quick Reply: Focus RS mk1 Aftermarket Water Temp Gauge
