Focus Mk1 EML & Lambdas
Old 25-01-2011, 07:15 AM
Mr cemex
Mr cemex's Avatar
Unhappy Focus Mk1 EML & Lambdas
Hi folks,
(im new here so be kind)
I just had the cat system changed after hearing some rattling noises inside the old cat at low revs. EML was still on when i picked it from StS garage.
So i took it to my local garage who told me that the front lambda sensor needs replacing as the "cables" were loose.
I reset the light via batery trick, but the lights came back on after 15 minutes. So i bought a new lambda and changed it myself to save labour cost.
Reset the light just in case but the EML came back on again after 15 minutes.
whats up doc?!
I might swap the old front lambda for the back one and see what happens.....
Old 25-01-2011, 07:34 AM
martysmartie
martysmartie's Avatar
You need to have the fault codes read really as there must be another sensor which is outside it's limits illuminating the EML, if it's the Lambda then it may be the wiring to it. Strange it's only happened since the cat was changed.
Martin
Old 25-01-2011, 10:39 AM
Bailes1992
Bailes1992's Avatar
Get a code reader on it. What engine is it?
Old 26-01-2011, 06:34 AM
Mr cemex
Mr cemex's Avatar
Its a 1.6 Lx.
I will take it back to the garage and see what the reader says.
Can i swap the old front one for the rear one and see what happends ?
thanks for the replies folks,
Old 26-01-2011, 06:50 AM
Bailes1992
Bailes1992's Avatar
Do you have 1 or 2 lambdas?
You may have pre and post cat or just pre cat.
Theres a Maf inside the inlet manifold, could be that too.
Tank Mike
Ford Focus Diesel
23-02-2022 06:09 PM
RSMK4TURBO
Ford Focus RS
14
19-09-2015 06:27 PM
JamboRS
28
14-09-2015 09:02 PM
Si B
12-09-2015 06:49 AM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
Quick Reply: Focus Mk1 EML & Lambdas
