focus 1.8 tdci egr valve cleaning
Old 14-09-2010, 06:12 PM
focus111
focus111's Avatar
Wink focus 1.8 tdci egr valve cleaning
hello every body , i'm new in this forum , i'm owner of ford focus 1.8 tdci (2009) duratorq , i'm experiencing some troublshootings , like engine knocks onacceleration around 2000 rpm with some fume and loss of performance so ,l'm thinking about cleanind the EGR valve ...so if somme one can help me to extract this valave , i'll be very gratful ...many thanks
Old 14-09-2010, 06:30 PM
B19 JUB
B19 JUB's Avatar
complete manifold off im afraid which is intergrated with exhaust manifold ie turbo too.if its 2009 model why dont u take it into your dealer to have it looked at under warranty
Old 15-09-2010, 02:21 PM
focus111
focus111's Avatar
hi B19 ,thanks for your message , yes i do have warranty on my cus till december , i've took it to ford service last week , i think they had done only pcu update , but the probleme back after few miles ...
Old 04-10-2010, 02:50 PM
Archibald
Archibald's Avatar
In 09 models, the EGR is detachable and does not require manifold removal (real pain as the exhaust has to go first then intake). I don’t have too much experience with this one but the main thing is that it needs a proper cleaning not just spraying with carb cleaner.
More importantly, you have to check whether it’s the EGR that’s causing problems. Did you check fault codes? Frozen EGR is usually shown as EML light on.
Old 04-10-2010, 06:30 PM
focus111
focus111's Avatar
hi , i don't have any code ..but according to ford mecanics ,they have to change the injectors and then the EGR manifold..
Old 04-10-2010, 07:17 PM
Archibald
Archibald's Avatar
And then DMF... Standard mechanics explanation for their lack of knowledge about 1.8 tdci.
I can help you but you would have to get codes. You can try the dials trick - press the dials reset button while turning ignition on. It should be explained on the forum how to get codes.
Old 04-10-2010, 07:27 PM
focus111
focus111's Avatar
hi ,archibald , i hugely apreciate your help...please where can i find the dials reset button ??? thanks a lot
Old 04-10-2010, 07:33 PM
Archibald
Archibald's Avatar
MKI - day trip reset button (next to the mileage display)
MKII - day trip reset button - indicator stalk.
Press it and turn ignition on holding it. Hold it for a 2-3 seconds and release it. There will be a new sign on your mileage display. Keep pressing reset button till you get to one with "DTC" - read codes is you can (4 digit).
BTW - where are you from?
Old 04-10-2010, 07:37 PM
focus111
focus111's Avatar
yes ,i'm from algeria ,...i think i do not have any button ;my focus is 2009...any way i go down to the garage to verify just 5 minutes
Old 04-10-2010, 07:54 PM
Archibald
Archibald's Avatar
Indicator stalk - check the tip of it. There should be a button there.
Old 04-10-2010, 08:06 PM
focus111
focus111's Avatar
hi ARCHIBALD i've found the test so : " DTC 00 # none " like this
Old 05-10-2010, 11:23 AM
Archibald
Archibald's Avatar
So no fault codes - I would suspect it's not an EGR valve, but you can always clean it and check if there's any difference.
Old 05-10-2010, 08:03 PM
focus111
focus111's Avatar
hi ?YES I THINK SO ; i think there is probleme with the injectors because there is a gray smoke at 2000 rpm and somme knocks ???... but how can extreact the EGR i can give you somme pics ok my duratorq 1.8TDCI
Old 06-10-2010, 08:50 AM
Archibald
Archibald's Avatar
Please send the photos and I will show you how to undo it. It's quite easy on yours.
Injectors on your 09 tdci are made by Siemens and I have not seen them going before.
Knowcking noice can be a DMF which even now is crap...but even more expensive crap than old ones.
Old 06-10-2010, 05:56 PM
focus111
focus111's Avatar
hi archi , but it bit dificult to send photos on this web , it needs url adresse ...to u have email adresse?
Old 06-10-2010, 08:01 PM
Archibald
Archibald's Avatar
Post it here
www.imageshack.us and paste link for forum
Old 06-10-2010, 08:16 PM
focus111
focus111's Avatar
Old 06-10-2010, 08:17 PM
focus111
focus111's Avatar
look just before
Old 06-10-2010, 08:19 PM
focus111
focus111's Avatar
http://img440.imageshack.us/i/18092010630.jpg
http://img18.imageshack.us/i/18092010636.jpg
http://img695.imageshack.us/i/18092010635.jpg
Old 07-10-2010, 10:13 AM
Archibald
Archibald's Avatar
EGR body itself is a part of the intake manifold and as such cannot be completely removed, but as you see on photos, the valve can be removed, by undoing 4 black bolts (there are 3 on the first photo).
Clean the valve and clean the body.
Old 07-10-2010, 04:35 PM
focus111
focus111's Avatar
hi ...yes i think the valve is incorporated in the manifold ...but when you remove the 4 bolts you find only a rotating spare no valve look at this photo:
http://www.forum-auto.com/pole-techn...ujet539087.htm
Old 09-10-2010, 08:52 AM
Archibald
Archibald's Avatar
Try to pull it.
Old 06-01-2013, 08:20 PM
bananz
bananz's Avatar
Hi. Having trouble locating EGR in 2005 focus 1.8 tdci! Disconnected the electrical part and removed 4 bolts to reveal brass cork screw type thing which is reluctant to come out. Should I persist in trying to remove this or is there another way in???
As you can probably tell I'm not too car savvy, so any explanation will have to be blow by blow please.
Car is emitting clouds of white smoke on start up and is reluctant to start on cold days - got someone to check for fault codes and it threw up EGR. After taking things apart and putting together again, fault code has changed to glow plug!! and now have the engine management light on and car is in limp mode. What is going on???? Can anyone out there help??
Old 14-01-2013, 09:53 PM
mearnsa4
mearnsa4's Avatar
Bet you feel whole lot betterer 2day, lol!
Old 15-01-2013, 11:15 AM
bananz
bananz's Avatar
Indeed I do!
Old 27-01-2017, 07:20 PM
FastLife91
FastLife91's Avatar
Hi
Does one need to have access to work under the car to complete this job or is it all done from above ?
Is the turbo easily accessible once the manifold is removed or are other parts preventing it from being removed ?
I have a 2006 mk2 ford focus sport 1.8 TDCI, I think it is the same engine you have ?
thanks
CossieRich
30
08-09-2015 10:08 PM
Ben26
Ford Focus Diesel
18-08-2015 03:42 PM
Bailes1992
16-08-2015 07:14 PM
taylora1409
12-08-2015 12:06 PM
Quick Reply: focus 1.8 tdci egr valve cleaning
