Mystery Pipe?!?!?!
Old 20-10-2007, 04:31 PM
james.dylan83
james.dylan83's Avatar
Default Mystery Pipe?!?!?!
A challenge fellow focus heads. My 1800 zetec has been idling badly, now 90% sorted thanks to cleaning out the iscv, but theres a hose which has become soft and collapses when the engines running and this seems to effect the idle?? Anone out there had this problem before or know what the hose is called/does.
The hose comes out of the back of the throttle body and then runs under the coil pack into a plastic pipe which seems to go into the engine block?
The question has been asked before as to what this is but no answer posted.
thanks to anyone who can help
Old 20-10-2007, 04:36 PM
MATT222
MATT222's Avatar
emissions pipe!! it sits on the back of the inlet manifold
Old 20-10-2007, 04:56 PM
james.dylan83
cheers matt.
What's it do with emissions and would it effect idle?
Old 23-10-2007, 07:13 PM
MATT222
MATT222's Avatar
it vents the crankcase emissions into the inlet manifold,when they split they allow air in to the inlet manifold casing the revs to rise fall and stall
usally you will require a idle valve afterwards.
Cosnada
07-01-2016 05:30 PM
07-10-2015 12:56 PM
stephenb4506
33
02-10-2015 06:25 PM
Fudgey
21
30-09-2015 06:19 PM
mpilk
27-09-2015 09:21 AM
Quick Reply: Mystery Pipe?!?!?!
