Mk1 1.8 tdci power problem
Hi everyone,
First post here, I hope ye can help me
I have a problem with my 2003 focus tdci (115ps).
Basically it loses power at high rpm. In first gear it revs to redline no problem with plenty of power. In second gear it loses its power at about 4000 rpm, third gear at ~3200 rpm, and so on. It has perfect power to these rpm's, and then it can only slowly creep up to redline.
I can't find anything online that I haven't tried already.
Here are the things that I have done:
-Checked turbo shaft, no play
-Full service last week; air, oil, fuel filters done, oil change
-EGR blanked, made no difference except for quicker throttle response
-Cleaned MAF sensor
-Checked hoses, new silicone hoses put in last week
-Cleaned out air intake hoses and intercooler
-No warning lights ever come on
I really hope someone can help me with this problem, it's driving me nuts
Thanks!
Cian
-Cleaned MAF sensor
Thanks!
Cian
Hi everyone,
-Cleaned MAF sensor
Thanks!
Cian
-Cleaned MAF sensor
Thanks!
Cian
Sometimes my turbo doesn't boost fully, it feels like it's holding back then all of a sudden it's fine again.
(Focus Mk1 TDci sport 115ps 2004)
Mine never fixes itself, constantly doesn't boost after whatever rpm
I came across it on a google search after numerous other people were suffering the same symptoms
I don't fancy removing the manifold/turbo as it's a full day job and a right pain in the arse, I can't use my garage as the cossy is in there, so it would be on the street
I don't mate, there may be but I'm unaware of it and from what I've heard swapping it with the EGR control solenoid wont work.
Here is a description of the symptoms I had (taken from a previous thread)
Car starts fine but some times as soon as I move off I can feel something’s not quite right, car is very sluggish and the throttle has to be pushed down considerably further than usual to get it to pick up ? Once I’m moving the car drives fine if a bit unresponsive, then without warning and with no further movement of the throttle the car will start to pick up and gain speed up to a certain point. From now on the car will drive and accelerate as it should but only up to about 3200 – 3500 rpm, from this point on it feels as though the car is wading through custard and it creeps (and I mean creeps !) toward the red line. Once another gear is selected the same thing happens and it again only revs freely to the above figures.
Ok so I had a go at moving the actuator today, and as hard as I tried I could only move it about half a centimeter at most. I assume it's meant to be able to move further than this?
I would say it should have a few centimetres of movement so I would think your first port of call is to establish why it's sticking and then free it up. Have you given it a good old squirt of anti sieze fluid to see if that helps ?
Ok so I took the solenoid off today... It's absolutely perfect! The arm goes up and down perfectly.
But, the arm on the turbo is solid, and I mean solid. I was trying to lubricate and pry it free, but no use
What the hell do I do now? preferably without removing the turbo from the engine... Try the antifreeze?
Thanks for replying mate
Any chance you could get a few pics up ?
When you say the solenoid is perfect what exactly d'you mean ? When I took mine off it "looked" identical to the good one but obviously was mullered.
Hi mate, sorry I probably could have made that clearer, the solenoid is ok, it was the vanes that were sticking.
So, we spent the day taking the turbo out, stripping it and found that the ring that moves the vanes was stuck rock solid, a huge amount of carbon and rusty stuff had built up and clogged it.
We cleaned it out with egr cleaner and now it's very clean and moves perfectly, so we're now putting it all back together and hoping for the best
Thanks man. Well after a bloody tiring evening it's all back together now... Took it for a spin and Jesus Christ one of the intercooler pipes blew off, what a bloody fright I got! Thought the turbo had somehow blew itself apart.
I haven't tried bringing it past 3000 rpm because I'm so nervous about it... Might wait for a while and leave everything bed in...
Anyway thanks for the help mate, hopefully it has been sorted
Sounds good mate, if it pushed a pipe off the intercooler it's probably a sign that the boost is back up where it should be and I think taking it steady for a few hundred miles is a good idea.
Ok so I've done 200 miles and the car has no problems revving up to and past 4k rpm
However, the car doesn't seem as powerful as it used to be? Like before it used to force me back into the seat until it hit 3k rpm at which point it stopped, but after I cleaned the turbo it doesn't seem to really force me into the seat anymore? It is still quicker though, since I can now use all the rev range.
Any ideas?
Any ideas?
How long did it take you to take it off to clean?
I've been having a look at mine and can't honestly see how I can get it out, it's doing my head in now so I'm gonna have to do something......
Can you describe the sticky vanes a bit more or have a pic handy so I know what I'm looking for?
thanks
thanks
thanks
thanks
Sorry I have no pictures but I think my father took one or two on a camera at home but won't be able to upload them till Friday.
Ok to find out if the vanes were sticking, we took the turbo out and found the the whole actuator arm was stuck solid. We thought it was the solenoid, but after detaching that we found it was perfect, and that the arm piece on the turbo was the part that was stuck, indicating the vanes were stuck, so we stripped the vanes part of the turbo and cleaned it well.
To get the turbo out we had to remove a lot of stuff, like the air inlet with the egr valve, and removed the bolts attaching the turbo to the engine.
Make sure you take pictures of the turbo when you have it apart so you know how to put the bits back together, there's really small pieces that come out so don't lose them
Any other questions let me know
Oh I recommend to just take everything off so you have lots of room to work, we took off the intercooler and all piping, the battery, the air box and snorkel. Actually while you have the snorkel off, check it for tears and gaps, ours was in shocking condition with a 4 inch hole going around the elbow!! Which must have left in a lot of unfiltered air
Yeah it is
Nope I didn't replace anything, except for the intake pipe because it was in brutal condition. Oh yeah I used egr cleaner to help clean the vanes.
Good luck and let me know how you get on
I had a look at a Connect TDCI 90ps (Lynx engine as per Focus) last week with lack of power, felt like turbo not boosting, this one had a map sensor on the bulkhead and the pipe was disconnected where it goes under the bottom of the EGR valve on the intake.
Simple fix!
Simple fix!
vdun01
Ford Fiesta
05-10-2017 08:14 AM
Ben26
27-08-2015 08:56 PM
