Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
18TDCI Batt light..
Old 19-02-2013, 02:08 PM
wardie222
wardie222's Avatar
Default 18TDCI Batt light..
Hi all,Iv searched the net for help on this but cant find any at all,
So im hoping someone here can help me out with some advice,Ok heres whats going on in short.
18 TDCI 115ps.2003.it was a bit of a bad starter when cold,battery would die trying most cold mornings so *new calcium battery fitted* which helped loads by having the power to turn it over long enough,but smoke on start so *new bosch glow plugs fitted* Great the car now starts no smoke ect just perfect,well so i thought...Now after a cold start the battery light stays on! it will stay on till i warm the car(say 2-3mins driving) shut it off and restart it then now battery light and stuff like front windscreen heater aircon ect can be used..Anyone have an idea what is causing this?
Thanks in advance for any input..
Old 19-02-2013, 02:45 PM
cossiejay
cossiejay's Avatar
check the altenator and welcome to the site
Old 19-02-2013, 02:57 PM
wardie222
wardie222's Avatar
Thank you for the welcome,every things fine as in the battery charges,it only happened after fitting new glow plugs,just went to my local altenator chap,never heard of it check earths maybe was hes repley,other garage guy was also lost on this one,i asked if maybe it was the relay for glow plugs as its onlt started after fitting new ones,no he said,your battery light would stay on,check earths he said lol...so im going to take the intercooler back off and check i ent messed a wire up some were..this has everyone stumped as the altenator is charging the battery.WD40 over kill maybe
Old 22-03-2013, 11:47 PM
akito-man
akito-man's Avatar
Location: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
Smile
its your alternator replacing the spent volts used to crank a high comp engine over.
its normal as the battery only hold 14 ish running,and will worry the ecu at 10and a half volts causing it to go into safe mode shutdown.(gradually removing power to systems,i.e. power steering,brake servo,dials ,etc.
tip
make sure you turn ignition on to warm plugs (yellow coil dash light)
when thats out crank to start.
when stopping,let turbo spool down,with radio/heaters/lights/etc off,
then when you start next day, the battery will have the best power to start.
lets know if this helps!
Old 24-03-2013, 06:02 PM
bullsrs
bullsrs's Avatar
Check the other leads attached to you battery leads, had the battery light come on and go off a few times on an escort si I fitted a 2ltr into, good luck mate
whizzisat114
01-09-2015 02:19 PM
rabmc
07-12-2006 06:06 PM
andyt
24-09-2005 11:45 AM
B19LRW
17-01-2005 10:09 PM
xrsi
12
18-09-2004 10:37 AM
Quick Reply: 18TDCI Batt light..
