Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Fuel consumption TDCi?
Old 05-10-2011, 06:12 PM
Icekottarinn
Icekottarinn's Avatar
Default Fuel consumption TDCi?
I would very much like to hear from you on this topic.
I have TDCi 2005 and the fuel consumption now (temp is 5 to 10°C)
6,7 l/100 km.
Is that normal?
If not, what to do or check?
Thanks!
Old 07-10-2011, 07:44 AM
oldford
oldford's Avatar
It would depend on which engine you have. Obviously a 1.4 would be using less than a 2.0 litre engine. If you look at test reports for the car then a 1.8 115bhp is using around 6l/100km and a 2.0 litre is using a little more than 6l/100km - which is a lot more than the factory promesses.
Old 07-10-2011, 05:08 PM
Icekottarinn
I have the 1,6 Zetec (I think it is called)
So, appr. 6 to 7 is alright then or normal?
Old 07-10-2011, 05:50 PM
oldford
oldford's Avatar
Feul usage sounds a bit high, but it could be down to how/where it is used and the personal driving style. Only city use? or not?
Check brakes. Check tyre pressures. Have the engine checked by a dealer or somebody with a dealer equivalent scanner.
Old 08-10-2011, 10:52 AM
Icekottarinn
90+% city drive, and tyre pressure, engine all is okay. I have not changes the air filter though, will do so.
But it would be very useful to hear from others TDCI owners, on there fuel consumption....
Old 08-10-2011, 11:26 AM
Dal_
Dal_'s Avatar
I'm currently averaging 5.66 l/100km which in imperial is about 50mpg in my Mondeo ST TDCi. That's the 2.2 litre though.
http://www.spritmonitor.de/en/detail/407789.html
Old 08-10-2011, 11:31 AM
oldford
oldford's Avatar
What is the state of your Diesel Particle Filter? Is that regenerated from time to time? Or are the trips you make too short and is the engine management system constantly trying to regenerate the filter (and thereby increasing the fuel usage)?
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
timsrs
13-11-2018 11:48 AM
20/20 vision
29-09-2015 11:27 AM
The Enigma
29-09-2015 10:31 AM
Sp3no
27-09-2015 07:23 PM
Quick Reply: Fuel consumption TDCi?
