MK5 1.25 how to change lifters/tappets
hi all,
my 1.25 mk5 has been sat in the garage for almost a year now, and i need the space. i've not made any time for it at all. too many holidays means i've not put the time or money aside to fix her.
i've borrowed an automotive stethoscope and the locking bar and pins for the cams,. i'll replace the lifters. I've got a whole new set of 16 to put in.
the engine mount doesn't need to come off because I'm not changing the belt ... is that right? it's only done 20K since it was done.
how do I remove the cams without messing any timing up? are they ok to take out with the setting bar in place?
how are the lifters fitted? just pushed on?
thanks
thanks
what do you mean 'cart change them'? they just pull out? suction cup them out?
can i just take the cams out after the belt is removed, after i've loosened the cam pulleys?
Ben
The little SE shouldn't tap, they should be nice and smooth.
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
