Fiesta This forum is for discussion of all things pertaining to the Ford Fiesta (Non RS / ST) Range of cars.
changeing a mk5 fiesta fuel pump
Old 28-06-2011, 05:48 PM
t16coupe
t16coupe's Avatar
Default changeing a mk5 fiesta fuel pump
hi i need to change a fuel pump on a x reg mk5 1.25 zetec fiesta whats the quickest way to do it some tips would be great thanks
Old 28-06-2011, 06:48 PM
Bailes1992
Bailes1992's Avatar
By doing it really really fast?
Don't think there is more than one way? Just pull up the rear seats and you shoudl be able to get at the lift pump from there?
There may be a strainer on the bottom of the pump, make sure you clean it before you put it all back.
Old 28-06-2011, 07:50 PM
t16coupe
t16coupe's Avatar
just the right way of doing it i have had the back seats up and carnt see a access flap
Old 30-06-2011, 06:33 PM
escort4x4
escort4x4's Avatar
you can either cut a hole under neath the seat, there should be a circle plate, cut that out n thats where the pump is, if not drop the tank
Old 13-02-2015, 11:27 AM
hornchurchmale
hornchurchmale's Avatar
in case anybody else thinking of this. on the mark 5 we have to drop fuel tank to gain access to fuel pump/sender unit as its a combined thing and no access under seat.
later fiesta apparently had access plate and a 'screw' type fitting.
ensure you have little full in tank when doing this! support car well. if no ramps? axle stand etc have a garage do it.
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
Prickly_buzz
25-08-2015 11:33 AM
kosienutter
31
22-08-2015 09:55 AM
dlwarrior
05-08-2015 10:19 AM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: changeing a mk5 fiesta fuel pump
