Escort S2 height problem
Old 12-08-2016, 09:38 AM
akronos
akronos's Avatar
Default Escort S2 height problem
Hello , I own a 1986 Escort S2 at which a complete set-up had been mounted (springs and dampers).
Because the height was too low ,i decided to buy original shock absorber and original spring. I bought a set of Kyb shock absorber (333802) and Kyb Kflex spring for front axle (RA 1388)
Once mounted here is the problem: Car it's too HIGH and Positive camber! The car it's undrivable..
See the pics :
Old 12-08-2016, 09:58 AM
haz87
haz87's Avatar
Wow, that actually looks like its on a jack!
Just quickly googled both part numbers and they list fine. Did you check part numbers on the physical shock/springs to check they were definitely right? Box may have been find, part not neccesarily.
Also, did you build the spring top cup assembly 100% in the correct order? (not that i can think of anything you could do wrong to cause such a lift - but worth me asking).
Old 12-08-2016, 10:07 AM
akronos
akronos's Avatar
Yes, the code on the single parts are ok :-( .... and the top it's mount correct...It is a mistery :-(
Old 16-08-2016, 02:22 PM
akronos
akronos's Avatar
New image, you see something that does not work ?
Old 16-08-2016, 02:33 PM
haz87
haz87's Avatar
The assembly itself all appears in order but that spring is HUGE! Thats your problem
Old 16-08-2016, 02:45 PM
akronos
akronos's Avatar
The code stamp on the spring are RA 1388 .....it's the correct code....
Old 16-08-2016, 02:59 PM
haz87
haz87's Avatar
That may be so, but thats the reason for your excessive height IMO
Old 16-08-2016, 03:09 PM
akronos
akronos's Avatar
What do you think?
Old 16-08-2016, 04:02 PM
akronos
akronos's Avatar
I also have a spring kit of automotive FK,the short spring is for front ?
Old 16-08-2016, 10:18 PM
nigel b
nigel b's Avatar
what is the length of the new shock compared to the old one?
deanflowers
50
14-12-2018 08:34 AM
Rs(555)
28-02-2016 08:31 PM
CliffRS4
43
29-01-2004 10:19 AM
CliffRS4
33
22-11-2003 07:04 PM
Quick Reply: Escort S2 height problem
