Cosworth FWD engine in to a MK3
Has anyone on here ever put a cosworth YB in to the front of a mk3 and run it through the front wheels? looking at different engines for my MK3 early 2 bolt strut top shell and was wondering whether it would fit without structural modifcation to the shell? i know the 2 bolt shell is slightly narrower then the later shell.
cheeRS for any help, Luke.
Seen it done id day you'd be better off going zetec turbo alot cheaper
Spanner monkey
Someone on here did a series 2 front wheel drive cossie, was a lot of work and very tight on the bulkhead with the inlet.
Had to chop the inner wing on the driver side also to clear pulleys and belts!!
Cheers for the reply chaps.
i dont want to do any cutting panels as the car has just been sprayed and is mint! i want to do something different but without modifying the panels.
bigryrs (14-11-2015)
Looks perfectly at home. My mate had a mk6 with one in fwd. went like a goodun!
Always a pleasure!
What FWD gearbox is used to do this?
I'd also recommend ZT but that's purely on price, if you can afford a Cossie build and want one then why not, certainly looks good in the bay! lol
Theirs an unfinished project mk4 on ebay exactly this fwd cossie chances of that
Always a pleasure!
