Group A coil or not
Old 20-09-2015, 12:15 AM
beller
Turb
beller's Avatar
Default Group A coil or not
Hi all, want to replace my current cheap europarts ignition coil on my 144bhp ERST not sure im getting a decent cold start spark.
Should I get a group A coil or is this a bit unessasary
or a standard bosch coil? http://www.burtonpower.com/bosch-blu...221119027.html
and.... do I need the little ballast resistor?
Thanks in advance folks
Old 20-09-2015, 02:14 AM
simonmcf
simonmcf's Avatar
I recently got a group a one on email for 15. Bolted in but not tested but it seems to get good reviews on a number of forums
beller (21-09-2015)
Old 20-09-2015, 11:30 AM
beller
Turb
beller's Avatar
Thanks simonmcf, yeah seen some aswell but usally quite highly moded cars
I would get one but you have to get the loom aswell so for the sake of just spending money after money do I acually need this or will the bosch coil be more than enough
cheers
Old 20-09-2015, 03:04 PM
nigel b
nigel b's Avatar
std. coil will be fine,and alot cheaper!
beller (21-09-2015)
Old 20-09-2015, 03:45 PM
Chopshop85
Chopshop85's Avatar
I've had a Magentti Marelli group A one on my ERST for several years an it's still going strong. Was only £7 more than a bosch std replacement and there's no loom for them, you just change the connectors to spade. They'll even fit using the original bolt holes.
beller (21-09-2015)
Old 20-09-2015, 04:36 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
The loom is just a rely that is triggered from the original coil wiring which then switches a feed direct from the battery to the coil. That way you no you have good voltage at the coil and not power going through old wiring that could have a resistance in it
beller (21-09-2015)
Old 21-09-2015, 12:53 AM
beller
Turb
beller's Avatar
Thanks for your replys folks, think i'll go for the grp a with a new loom
Coil
http://www.ebay.co.uk/itm/1517385418...%3AMEBIDX%3AIT
Loom
http://www.ebay.co.uk/itm/1718005405...%3AMEBIDX%3AIT
Thanks again
Old 21-09-2015, 04:13 AM
Chas
Chas's Avatar
No harm in that.
There is no point going with an aftermarket coil ; I have had no end of trouble with them, often giving me more issues than when I had the original item on?
However, check your wiring and ensure that you are getting 12V at the coil.
01-11-2015 06:53 PM
A.t.p
23-10-2015 07:54 PM
07-10-2015 12:56 PM
IainRS1700T
25-09-2015 06:44 AM
davidfox280585
Shows & Track Days
17-09-2015 10:09 AM
Quick Reply: Group A coil or not
