engine popped during boost!!
Ad just fitted new head that ad been skinned with standard gasket n standard bolts n was running ok! Did turbo a little few tyms with no probs! N went to show my friend n took him out DiD the turbo n boom! Felt like some think popped off n ad white smoke n n miss firing!! N was no water in bottle!!
I no the cars running some serious boost!! Is second gasket it's done it to in 2weeks!! I've brought car as project so don't no its past etc!! But previous owner reckoned was 200bhp+ !!Been told block could be twisted and to check that n to get uprated gasket n non stretch head bolts!! Work starts tomorrow!! Fingers crossed
Ask me a question!
First thing that I notice is the fact it's running "serious" boost. If you didn't know mfi has issues suppling fuel for serious boost. Then if it can supply the fuel it's normally a question of how long before it goes out of tune. In your case it wasn't tuned to start with. So expect nothing but failure.
2 gaskets in as many weeks is unheard of. Obviously has been rushed and not done right without having a setup a tune after.
For your piece of mind and pocket your best off fixing it coming over and let me check your setup and tune for FREE before any one starts.
Checked head for twisting n is ok n checked block was ok to!! Av refitted a old fully metal gasket i got off my spare engine n its working fine tho not done the turbo just driving it between 2 n 3000revs!! Seems ok but not gonna risk doing the turbo yet!! Lol
I no it's a 88 model n as ad a series 1 gear box with LSD!!!! fitted!!
Cheers fir offer of retune mate where in UK are you?
Also second gasket was joke!! Mostly cardboard n little metal n after the 1st 1went changed my head as previous 1 could of been twisted which may of not helped .. like say running ok tho little lumpy n uneven!! Sum tyms running at 1000rev on idle n sometimes at 800rev on idle so deffo need set up .. tho I only live 5min from graham Goodes if you heard of them!!! Tho will cost ŁŁ
Was reading history n had a 2.0 bottom end fitted 2years ago n may be it was tuned to that n it's never been changed even tho it's now got a standard 1.6 one again!!
Is ok mate I got my rs for Ł1000 with blown engine and the body's clean with no clagg in it n never been welded and ain't cat c or oat!! The cars worth Ł4000 minimum wen it's running , it's that good n stands me at Ł1400!! Lol so don't think any1can call me an idiot!! But point taken
And the car is running now and have done some boost with no prob tho not taken it to limit and won't till I get it set up properly!! But seems ok now!! I've learned cheap eBay head gasket sets are no good!!
Ben
What do you mean by "done the turbo"?
No I wouldn't.i don't think its necessary for you to be called an idiot when you are asking for a bit of guidance!it must be very difficult when you are so perfect!!!!!
Ben
Of course you do, Plenty of foreign members on here have a better grasp of the English language than you.
So yes you are making yourself look like an idiot.
n n n(and) not forgetting there's always spell checker!
I fixed it for you. But to be fair I am perfect, In my perfect little world.
gchristophi
31-08-2015 10:36 PM
CabrioTurbo
01-08-2015 11:04 AM
