SOLVED!! annoying misfire / spluttering
completely random, hot or cold, take away or eat now - behaving like no or weak spark - anyone else had similar troubles
small turbo model
UPDATE! - re-set the ECU (by unplugging it & seems to haev gone away! - weird)
small turbo model
could be either - will check plugs this morn' but they have been there a while & had the prob occasionally with the last set - could well be lambda as the car does have to endure non booting quite often - cheers ppl!
not sure what i can do about that mind ???
mine is very jerky on light throttle and in traffic i have just been living with it but i would love to find a cure someone on here said it could be a throttle position sensor fault
1 Post
feck, thats quite a a gap, sure you dont mean thou
that = 0.6-0.7 mm,
you want as large a gap as you can run with , without misfires, start at 0.8mm, then if you have problems, yes drop down, but the small turbos run coilacks as std so shouldn't see many problems at 0.8 running std or stage 1 boost
that = 0.6-0.7 mm,
got a mate gringing a snap on scanner round soon - lets see what that says!
tried the fault reader & go confusign results!!
cheers all for plug gap info - will have a go asap
has anyone else done the wired LED fault code flash test ? just did it & got very confused with the results lol
i'm sure the codes translated as:
1. you have a walrus in the exhaust
2. nothing wrong at all matey - car then promptly stalls & wont restart
3. actually pointed to possibly a bad earth or fault in the ISCV
most confusing part of operation (as u can probably tell) was actually reading the autodata book correctly & trying to decide between what 2 sets of flashes i was counting - hopefully get the man & scanner round 2morro or thurs & see what happens!
still have an annoying 2000 rpm occasional judder but that has always been there - god knows what it is but all other fooking about has gone!!
SMART!
SMART!
make sure the ignition is off, remove ecu multi plug (you will need a 10mm spanner), give the contacts a clean while your there, plug it all back in again & hey presto, the stored faults in the ECU will be cleared!! (the EECiV will record & keep all faults & if said fault required it to adjust the mapping or something weird it will carry on with those settings!, at least that what mr spanner with scanner tells me)
rED
rED
SMART!
SMART!
cars running with coil packs quite often get this problem it seems but i have heard it from dizzy jobs aswell ?????
like i said earlier WEIRD!
wheelwizardrefurbs
22-09-2015 05:45 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
2000rpm, car, closed, cosworth, escort, ford, hot, misfire, misfires, misfiring, occasional, passionford, spluttering, throttle
