escos headlamp washers
Old 31-05-2005, 09:19 PM
Dave Henshall
Dave Henshall's Avatar
Default escos headlamp washers
the pump i have just found was disconnected on mine and the pump looked pretty grubby and furr coming out of it, so ive cleaned the car end of th connector and robbed one of the spare under back seat water injection pumps(finis 6088981) which are exactly the same it turns out...
question is,, when and how long should the pump actually spray, a can hear a relay clicking in with the headlights and wipers on if you go to squirt the windscreen, but the headlamp washer pump doesnt run, does anyone know which relay it is, im assuming its a timer relay which runs on for x amount of time once energised...?
Old 01-06-2005, 09:37 AM
THE RADMAN
THE RADMAN's Avatar
the relay is R22 its a blue one,fuse is no 23 unless its a l/h/d
Old 01-06-2005, 09:57 AM
Glenn5
Glenn5's Avatar
silly q but have you tried it with the lights on m8???????
Old 01-06-2005, 10:01 AM
Dave Henshall
yep, lights on , wipers on, and screen washer running but disvonnected so i can hea rthe headlamp pump.
cheers radman, ill pull it out 2nite and see if its working...
Old 01-06-2005, 10:41 AM
july1
july1's Avatar
you don't need to run the wipers just the headlights.
First of all check if you have a voltage on pump. (it can be just blocked)
Old 01-06-2005, 11:06 AM
Dave Henshall
no voltage to the pump, but the fuse is ok, so leads me to think that its the relay that fooked....
Old 01-06-2005, 11:46 AM
july1
july1's Avatar
I removed mine as I'm using the pump to spray on the intercooler but as I live in France it won't be easy...mayby you can find find someone near you and borrow its relay to try.
fusebox are known for there poor quality on welding but I never heard about a bad weld on headlamp wash...but who knows!
Old 01-06-2005, 12:51 PM
Dave Henshall
its got a brand new fusebox, i'll try the realay 2nite and see if it works on the bench.
Old 01-06-2005, 01:20 PM
Azrael
Azrael's Avatar
When you sort it out please tell me if you can set the squirts. I mean are they glued in or can they be adjusted? I tryied moving mine because they don't hit right spots on the lamps but can't move them.
Old 01-06-2005, 01:42 PM
Dave Henshall
Old 01-06-2005, 01:56 PM
Azrael
Azrael's Avatar
So Dave tell me when you check it out
Old 01-06-2005, 08:14 PM
Dave Henshall
found the relay, its as the info above, and it does click in for a split seccond but isnt latching, so i reckon its a new relay needed. i found the problem that was draining the battery aswell, the interior light delay re;ay was staying on. unpluged it and lpugged uit back in and that now is working correctly (why i dont know)BUT now the dashboard lights (elecroluminesence doesnt work think i might have blown the inverter when i tried a normal rely in the interior lights socket
Old 01-06-2005, 08:20 PM
Azrael
Azrael's Avatar
Dave - where is interior delay thing? My interior lights work with no delay.
Old 01-06-2005, 08:24 PM
Dave Henshall
its the tall yellow relay at the front of the fusebox...R17.
does your interior light in the roof have a 20sec setting on it...?
Old 01-06-2005, 08:27 PM
Azrael
Azrael's Avatar
It has "20 sec" sign on it. But just goes on and of when I close and open the door. Not like in my moms Focus where it is lit for some time after the door closed.
Old 01-06-2005, 08:32 PM
Dave Henshall
probably that relay that is to fault, if its fitted at all, it might just have a bridging link so that it works on/off just from the door pin switches alone.
could you do a me a favour and take a pic of the locations of your relays, according to the book, there are some that are not uses which ar e installed and some that are the otehrway round...
Old 01-06-2005, 08:35 PM
Azrael
Azrael's Avatar
My fusebox is a little bitchy to take out. Do you remmember my car is LHD? Is that matter in terms of electrics? I'm little afraid of taking all of that apart but if it helps you just tell me which pics do you want.
Old 01-06-2005, 08:38 PM
Dave Henshall
of course, left hand drive,, it does say in teh handbook that some things will be indifferent locations for a LHD model, namely the headlamp washer relay - but why, i dont know.
Old 01-06-2005, 08:39 PM
Azrael
Azrael's Avatar
of course, left hand drive,, it does say in the handbook that some things will be indifferent locations for a LHD model, namely the headlamp washer relay - but why, i dont know.
Which handbook? I don't see any electrics on any of my Escos manuals.
Old 01-06-2005, 08:44 PM
Dave Henshall
the ford vehicle handbook, the ones that you get with the car from new which tells you about which fuses do what, what oil to use and how to operate the control etc...
get this, just loooked on microcat, the headlamp washer relay is about Ł52!!!!!! and the interior delay one is Ł33!!!!!! fook mei!!! a trip to the scrap yard i think....
Old 01-06-2005, 08:55 PM
Azrael
Azrael's Avatar
I know, I got it.. in Swiss dialect of German
[qoute]
get this, just loooked on microcat, the headlamp washer relay is about Ł52!!!!!! and the interior delay one is Ł33!!!!!! fook mei!!! a trip to the scrap yard i think....[/quote]
Geez... and probably not avalible.
Old 01-06-2005, 09:24 PM
Dave Henshall
they look like standard parts and not cosworth specific so probably will be. gonna still try a breaker yard first though, as i can live without them working as they have never worked while i have had the car, as long as i know WHY they aren't woprking, its a job for a rainy day, besides, with morrettes fitted, they dont squirt in the right place anyway
Old 01-06-2005, 09:42 PM
Azrael
Azrael's Avatar
That's the problem I aways wanted to correct (that was what I was trying to explain in the beginning of the thread). Any ideas?
Old 01-06-2005, 09:51 PM
THE RADMAN
THE RADMAN's Avatar
you can swivel the jet [its like a ball socket] but its easy to snap it if it hasnt been moved for a while,the problem is getting something to fit in the holes/awkward angle
Old 01-06-2005, 10:20 PM
Azrael
Azrael's Avatar
Hmm are those expensive to replace?
Old 02-06-2005, 12:42 PM
Dave Henshall
just realised why the EL dials dotn light up.... ive got the panel off to get to the fusebox and unclipped the dimmer switch so the only thing that need replaceing now is the headlamp washer relay.
Old 02-06-2005, 12:46 PM
Dave Henshall
the jets are abuot Ł9 each, finis:
LH 6795023, RH 6795021.
Old 02-06-2005, 12:53 PM
Azrael
Azrael's Avatar
Muct order new ones and try adjusting them at some opportunity. If you manage to make them squirt in right places tell me. Please
Dave you're really good at that DIY :-D I am really scared of electrics.
Old 02-06-2005, 05:57 PM
Dave Henshall
ive just had a play with mine oo-err,,, if you put 2 small terminal screwdrivers in the slots on the jets at the top, you can moce them about like a ball jont and make them point whereever you want - within reason...
Old 02-06-2005, 06:00 PM
Azrael
Azrael's Avatar
I've tryied with mine and they won't move, I am afaid to brake them. Will order new ones before braking them
Old 02-06-2005, 06:05 PM
Dave Henshall
i squirted some wd-40 around them first, they were quite stiff to move at forst , but got much easier once moved a couple of times
Old 02-06-2005, 06:11 PM
Azrael
Azrael's Avatar
Will try tommorow then with lots of lubrication
155lee
06-09-2016 11:10 AM
155lee
24-10-2015 11:11 AM
gcfcos
59
06-10-2015 05:04 PM
DavidK
27-09-2015 02:55 PM
Mickeystewart
09-09-2015 04:04 PM
Quick Reply: escos headlamp washers
