Escort Cosworth Fuse Box.
Old 15-05-2005, 10:22 AM
Lillford 500
Lillford 500's Avatar
Default Escort Cosworth Fuse Box.
Can one of you very nice people help me?
I need to find out the Finis Code for the Fuse Box that goes into a 1994 L reg, Big Turbo Escort Cosworth.
Also, if someone can supply a photo of the top of the Fuse Box where the relays go.....well I'd be your best friend forever!!!!
Thanks very much.
__________________
Old 15-05-2005, 11:23 AM
Dave Henshall
Dave Henshall's Avatar
i replaced mine as part of the process of elimination when it was being a bad car,
these are the pics of mine (an early 1993 big turbo)
the finis is: 6728095
with this number printed on the bottom rh corner of the top: 93AG14A073BAA
It was about £200 from woodford about 2 years ago.
here are the pics of mine when i replaced it if they help....
Old 15-05-2005, 11:36 AM
Lillford 500
Dave, you're a fookin star!!!!!
That's exactly what I'm after!!!
Cheers Buddy, I owe you one!!
Old 15-05-2005, 11:38 AM
Dave Henshall
this IS what bbs if for
Old 15-05-2005, 01:30 PM
Speedy G.
Speedy G.'s Avatar
Remember that you need the EXACT same fuse box in your car as was in it m8.
There are different numbers out there as mine had the number 91AG14A073BE.
Old 15-05-2005, 04:16 PM
Lillford 500
The problem is that mine has had a different fuse box in it before I owned it.
The date on the box say's 1995 and my car's a 1994??!!
Are there different type's of Hi Spec Mk5 Fuse Boxes?
Old 16-05-2005, 08:07 AM
Dave Henshall
ah well, the build date of my car is october 92 but was registered in april 93, yet the fusebox has a 93 part number and is the original one as the engine number is printed on it....
Old 16-05-2005, 09:05 PM
Lillford 500
My mate has got me a brand new fuse box which, according to Microcat is the correct one for my car. But this box doesn't have an outlet for headlamp wash, so basically I'm none the wiser??!!
Old 17-05-2005, 07:35 AM
Dave Henshall
speedy, could you post up a pic of the top and bottom of yours to compare if it phisically looks different (ie different connections)
Old 17-05-2005, 02:59 PM
MATCOS
MATCOS's Avatar
where do these fuse boxes have probs-am I right in saying that water gets in?
if it does can you stop the process?
Mat
Old 17-05-2005, 03:56 PM
Dave Henshall
there are some rumours that is is water that gets in that causes them to die, personally, i just think its the naff contruction and they get dry soldered joints over age as the actual fusebox is quite flexible and is under a fair amount of stress when it is populated and clipped up where it should go.
just realised i should say, fao lillford, mine is a lux BUT doesn't have air con and doesnt have an electric sunroof or heated seats.
Old 17-05-2005, 06:50 PM
Speedy G.
Speedy G.'s Avatar
Dave,
Terribly sorry m8, I had EVERY damn picture of that fuse box but my HD went a couple of days ago and I lost EVERY BLOODY THING.
From what I can say from memory, it LOOKS the same as mine.
Old 18-05-2005, 07:49 AM
Dave Henshall
re your hard disk, have yuo tried spinrite - hard disk recovery program...?
Old 18-05-2005, 04:39 PM
july1
july1's Avatar
Personally I had trouble with the fuel pump relay connection on the board. The welding was broken so I had tension on the pump but no power.. The problem has been solved by simply dismantling the box and renewing the welding.. (All welding with power by the way) then new varnish on board..and back on the car!
Cost: 3 hours of work..for many years of happiness... so try this before supplying a brand new one...
Old 19-05-2005, 02:28 PM
Lillford 500
The saga continues.........
I've fitted a brand new fuse box to the Escos now at a cost of £220!!!!!
I realise that's rather steep but the good news is........everything works!!!!!!
I now have a fuel pump which turns off after a few seconds after the ignition has been turned on, headlamp washers that actually wash headlamps and a heated front screen that works!!!!!!!!!!!!
I'm a happy man!!
Thanks to everyone that gave advice on this thread especially Dave who posted much needed piccies!!!
May The Fords Be With You!!
Old 19-05-2005, 04:30 PM
Dave Henshall
Old 19-05-2005, 04:34 PM
Lillford 500
It turns out Dave, that my fuse box is exactly the same as yours!!
Old 24-10-2005, 02:36 PM
Tandy
Tandy's Avatar
as im having a couple of probs with my car im looking in to all the options and thought this info might help. im looking into getting a new fuse box. The no. of the fuse boxes listed above are different to mine so there is another type. fuse box no. is 91AG14A073BBD it is £132 plus vat from ford
I was also concerned about the date on my original fuse box becaue it is dated 1996 and my car is 92/93. I was told by ford that is more than likely i have had a new fuse box put on my car in that year or round about. Also spoke to ian rst and his fuse box was dated 98 ( cheers Ian ) so it's seems the date is just when the part itself was made this should hopefully put a few minds at rest
Old 24-10-2005, 02:56 PM
Chris Honeywell
Chris Honeywell's Avatar
Tandy i also put a new box in mine a few months ago
and the one your on about at a cost of
£132 ford told me that was for the 2 box types that fit into the small turbo Escort
My big turbo box was about £220
But yes the date is when the box was made
Old 24-10-2005, 03:01 PM
Damo V
Damo V's Avatar
Tandy
3BE code at the end of the fuse box doesnt appear to be correct.. Drop yours down check what the code is
Old 24-10-2005, 03:48 PM
Tandy
Tandy's Avatar
sorry got number slightly wrong. Ive edited the post above with fuse box number but just to confirm again 91AG14A073BBD
got ford to quote price and again £132
Old 24-10-2005, 03:49 PM
Damo V
Damo V's Avatar
still need to drop yours down and comapre the last 3 digits
Old 24-10-2005, 03:53 PM
Tandy
Tandy's Avatar
didn't know it had any other numbers on it
Old 24-10-2005, 03:54 PM
THE RADMAN
THE RADMAN's Avatar
once youve removed it,unclip the box and take it apart,have a look at the soldered joints using a magnifyinglass if nec and you will see any that have started to bubble or melt,take it to an auto electrician to resolder ,job done,save yourself a fortune
Old 24-10-2005, 03:56 PM
Damo V
Damo V's Avatar
In this pic of Daves, the last 3 digits (Bottom right) of the new fuse box have to match the old one
Old 24-10-2005, 03:58 PM
Damo V
Damo V's Avatar
Nick, IMO it aint worth repairing.. mine had previously been repaired when i bought the car 2 years later it still buggered up again
The new ones are apparently mdified so it shouldnt happen again
Old 24-10-2005, 04:00 PM
Tandy
Tandy's Avatar
got you in that case my last three digits are ( BBD )
Old 24-10-2005, 04:05 PM
Damo V
Damo V's Avatar
Mine were BAA... and that was a £200 box ..
Old 24-10-2005, 04:11 PM
Tandy
Tandy's Avatar
ford sometimes change there prices on parts, cosworth stuff seems to have it's moments of coming down in price or so i was told when i bought my hockey sticks were £90 now more like £75 not much but it all counts. If i end up needing the box with vat i will end up paying £170 ish
so not far off your price
Old 15-11-2005, 06:01 PM
Speedy G.
Speedy G.'s Avatar
FINALLY found my pictures again.
As you can see, a tad different from yours.
Old 18-11-2005, 12:46 PM
Simbo
Simbo's Avatar
The 3 red cables with the nut on them, can these go onto any of the bolts on the fusebox or do they have to go back onto the ones which they came off, i took my fusebox out and now i cant remember which ones go where
Old 18-11-2005, 01:59 PM
Dave Henshall
it will probably work any way, but they are protected by different size fuses at the battery end...
Old 18-11-2005, 03:33 PM
Damo V
Damo V's Avatar
I believe one of them is heavier guage wire and as Dave says, there are 2 different fuse sizes at the battery, IIRC 2 60 and 1 80 amp, so the heavier wire will be the bigger fuse... looks from the pics above like the middle wire is the heavier item???
I know it doesnt help much now but I marked mine and my old fuse box before removal...
Old 18-11-2005, 05:48 PM
Simbo
Simbo's Avatar
i did mark mine and took pics of it so that this wouldnt happen but the pics have turned out very blurry and i cant make out which number is on the masking tape.
Looks from my pics tho that the heavier gauge wire is on the bottom connection.
cheers
Old 18-11-2005, 05:51 PM
Damo V
Damo V's Avatar
if you arent in ay rush i will look at mine next week for you??
Old 18-11-2005, 06:30 PM
Speedy G.
Speedy G.'s Avatar
By the way, can anybody explain why I'm missing some relays on the fuse box that you have Damo?
Old 18-11-2005, 06:32 PM
Damo V
Damo V's Avatar
How do you know?? you havent seen my fuse box
which ones you missing??
Old 18-11-2005, 06:33 PM
THE RADMAN
THE RADMAN's Avatar
Old 18-11-2005, 06:37 PM
Speedy G.
Speedy G.'s Avatar
Sorry, have seen a box on a post you did but I now see that it's Daves box.
Dave's box
My box
Old 18-11-2005, 06:38 PM
Damo V
Damo V's Avatar
cheers
Just looked at my old fuse box, and you can see it in the pics above.... the waires will only go in one place... well the fat one at least... if you look closely you can see they have plastic tab bits so they wont go into the wrong one!!!! Well done Ford LOL
Quick Reply: Escort Cosworth Fuse Box.
