injectors on st25
500bhp
i would like a bit more power .and people say the injector
are maxed out. i have just bought some hi impedance
injector's for my rover to use, and woundered if you can change the
standard cossy injector's to a bigger flow rate
Originally Posted by sailorbob
Yes you can, you just need to change the calibration to let the ecu know the flow rate of the new injectors.
can this be done mate.on my 600 rover you can't do anything with the ecu i had to add 4 more injector's running off a hks injector controller
this is how i got more fuel .it would be easer to just add bigger injector's in the cossy.what would happen if you just put bigger injector's in?
Why? Looking at your other cars, you obviously like to tinker with them. If you are running out of dutycycle on your injectors you need to turn the boost down or upgrade the injectors (another way is to up the fuel pressure but has all the side effects of changing injectors but also risks overloading the injector drivers). What's the spec of your car?
my escort is running 260 bhp and 300f/lb
does any body know the size of the standard injector's ?
what about a small increase in injector size?
Re: 220
EsCos SORN :(
And anybody used the Megasquirt system to tune a T25 EsCos?
mk3ste
17-10-2021 10:09 AM
DixieTheKid
11
06-06-2020 11:20 AM
