How many of you guys run 400+ bhp on std. MT75 box?
And how long time have you been doing that without issues?
Personally i think the durability and lifespan of the gearbox, has a lot to do with the way the car is driven, but i would like to hear your experience about this.
Maybe i'm totally wrong? I have not covered enough miles in my own car to have any experience with this, but i am aware of the problems i could or should i say will get? when running 400-450 ish on a standard box. So honestly i'm thinking about running with a lower boostpressure until i can afford a decent gearkit upgrade.
i was running 400bhp on a standard mt75 box no problems!! like someone else said its the way its driven that helps, and im not a slow driver but just didnt launch it at every junction!!!! by the way its rwd now Still got the box and it will go back on if i get bored of rwd!!! mmmmm maybe not then!!!!!!
It depends on the tolerances on the gears... many miles on the box is more backlash between gears so this makes it worse...
Most common issue however is 3rd gear and sometimes the 2nd gear... I have 400bhp and 520Nm of torque. I don't launch it off the line like a lunatic and I change gears slowly but I have broke 4 times the 3rd gear and most of the times with the engine at about 5000rpm... It has to do with torque and rpm imo mostly and not bhp...
what i did was to install an aftermarket boost controler and I made the car too produce boost without spikes and it helps alot, doesnt feel the same as before when you nail it but I am protecting the gearbox until the installation of stronger gears...
yawiejon
15
09-08-2015 06:36 PM
wheelwizardrefurbs
04-08-2015 06:23 PM
