The 'fins' on escos inner wings
Old 01-12-2007, 01:16 AM
david
david's Avatar
Default The 'fins' on escos inner wings
What are they for ?
None of the sierra's had them.
Old 01-12-2007, 06:17 AM
Bullett
Bullett's Avatar
i presume for strength,like a strut brace.they must have put them on due to the lack of preformance on the saff 4x4 in the rallying i would think.it wouldve been another aid to stiffen the car and get it round the corners properly.
i could be way off though
Old 01-12-2007, 07:13 AM
lowman
lowman's Avatar
i do not think they are for stiffening.
i think they are for cooling,it would lead of hot air from the engine bay and out in fresh air.
i may be wrong as well,,,but i cant see how it could be a strenght issue
maybe we are all wrong..and they just put it there cause they didnt have anywhere else to put it,
Old 01-12-2007, 10:11 AM
Bullett
Bullett's Avatar
are we talking the same bits? im thinking they are the bits that go from he strut top to the inner wing edge?
Old 01-12-2007, 10:14 AM
kjc300
kjc300's Avatar
No, I think he means the slots in the actual inner wings, sort of underneath the abs/master cyl gubbins, and the same the other side. Look like cooling type vents to me.
Old 01-12-2007, 10:56 AM
dave cos4x4
dave cos4x4's Avatar
get rid of some heat i would think.
Old 01-12-2007, 11:28 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
The "gills" are where the air is extracted from the engine bay and exits out of the back of the vents in the front wings, so is to aid cooling . You have to remember that the Escort was built to meet homologation purposes for rallying, so has lots of unique features not seen on any other Cosworths.
Old 01-12-2007, 12:28 PM
Bullett
Bullett's Avatar
lol shows ow much ive looked at one then never seen them.that explains the reason for the wide wings then
Old 01-12-2007, 02:59 PM
david
david's Avatar
fuck, I welded them up
Old 01-12-2007, 03:48 PM
dave cos4x4
david
why.
Old 01-12-2007, 04:59 PM
david
david's Avatar
The pass side was rotten there and down onto the bulkhead so I cut all that area out and welded in fresh metal. Drivers side was a little soft so I did similar. It was because of a previous bulkhead swap that had created a water trap the way it was done.
Knew I should have asked the question before though
not to worry as ive already thought of a way to replace them
Old 01-12-2007, 05:33 PM
dave cos4x4
drill some holes in there.
Old 01-12-2007, 11:17 PM
S1rst
S1rst's Avatar
gcfcos
59
06-10-2015 05:04 PM
stephenb4506
33
02-10-2015 06:25 PM
Iain Mac
30-09-2015 09:39 PM
Quick Reply: The 'fins' on escos inner wings
