Fuel level sender
Monte Geek
Fuel level sender
Do the fuel level sender floats ever get stuck my Fuel level isn't moving
The tank was recently dropped when my extra fuel pump and swirl pot where added, could it have been disturbed?
They can get dislodged from the float arm, they would have to be dropped very heavily to do this though, as float only sort of clips into end of arm so to speak.
have you tried filling the tank up, i cant remember if the float clears the bowl that sits in the tank around the sender unit.
If it does, im sure if you fill up, then would just correct itself maybe.
Originally Posted by THE RADMAN
warning light doesnt come on till its reading virtually nothing on guage on mine,there is still around a gallon in it though
use the gallon can to get you home, simple..
steve
my sender had problems after havving installed the 023 pump, for the next days it did not work, then it suprisingly started from itself to work again properly, very confusing....
