Tank - filter fuel lines
Old 19-05-2007, 04:54 PM
Rolls
Rolls's Avatar
Default Tank - filter fuel lines
As title guys - does anyone know if you can still get these from ford?
The one that connects to the filter with the push fitting needs replacing - the little pins you push in to release the fitting have seen better days - so much so, that one of the pins has fallen apart! - don't 'ya love shinkey old fords....
Old 19-05-2007, 06:37 PM
redrsmk5
redrsmk5's Avatar
Im sure Franco replaced these on his resto thread, give him a PM mate
Old 19-05-2007, 07:38 PM
K500BHP
K500BHP's Avatar
wouldnt mind knowing myself
Old 20-05-2007, 10:42 AM
L9KOS
L9KOS's Avatar
i actually managed to get some of these from PJ motorsport when i ordered the grpA stuff off em.... i had kinda foreseen em being fuk'd before i even started the job.
think they were bout 20 quid
Old 21-05-2007, 11:42 AM
Rolls
Rolls's Avatar
well....
apparently you can only get the filter - engine bay pipe from fords...
So... that then leads onto the question, what is the best way of resolving the other issue?
I don't mind quiping the tank - filter fitting, but will the pipe be on on the top of the tank with a jubliee clip holding it down?
Old 21-05-2007, 11:45 AM
Rolls
Rolls's Avatar
And, also, will normal quip be ok, or do I need the lined stuff?
FFS, I hate cars at times
Old 21-05-2007, 12:37 PM
COS 22
COS 22's Avatar
put a pic of yer old one up i may have a spare new one
Old 21-05-2007, 12:48 PM
Rolls
Rolls's Avatar
I would do, but they are still on the car
Old 23-05-2007, 11:03 AM
Franco
Franco's Avatar
You can replace 3 out of the 4 pipes (you cannot replace the return feed pipe which runs under the car)............
And now you're going to want to know the FINIS numbers!
Old 23-05-2007, 11:13 AM
Rolls
Rolls's Avatar
We'll, i've ordered the filter - pipe that leads to the bay, but apparently they don't do the tank - filter anymore.... - so aeroquip it is
(had the fini's already - cheers though matey! )
Old 25-05-2007, 06:39 AM
THE RADMAN
THE RADMAN's Avatar
this one anygood?? http://cgi.ebay.co.uk/Ford-Escort-Co...QQcmdZViewItem
Old 25-05-2007, 09:11 AM
Franco
Franco's Avatar
Thats the one you can still get, think he was talking about is from the filter to tank.....
Thats the return pipe to tank (from the metal pipe running under the car!).
Old 25-05-2007, 03:55 PM
THE RADMAN
THE RADMAN's Avatar
oh well better off in aeroquip anyway
Old 27-05-2007, 09:28 PM
Cozzie Bhoy
Cozzie Bhoy's Avatar
Ford don't do the pump to filter pipe anymore. tried them just this week. The return pipe to the tank is available. I used 8mm copper instead. The banjo bolt on the filter and the sender unit will take an 8mm compression fitting. Bent up some copper then the same as the plastic pipe. SORTED
Rob Wells
Ford Mondeo Including ST
18-04-2023 12:19 AM
JK12
33
26-04-2021 12:09 PM
15
07-10-2015 03:43 PM
gavt123
05-09-2015 10:03 AM
hopper350
04-09-2015 12:53 AM
Quick Reply: Tank - filter fuel lines
