Performance Ford featured Escos-might break
Thinking about another project so may have to break this one.It's featured in the latest mag and has many good parts.I would need a commitment on the shell to go ahead.Shell has only done 11k miles and was brand new in 97 and has the sunroof fitted.Engine is basically Martin's famous Gumball motor but with my ancills and the gearbox is a 909 Sport box with straight cut 1st gear.Many other good parts on this car.PM me if you have any interest.
Cos it's the only way to get a reasonable return back.The engine,with it's 8 injector set up and ecu,coupled with the gearbox stand me at almost 15K.The shell was 7 grand.Now i realise i will have to take a hit but most people dont even want to pay 15k for the whole car.If anyone comes in with something sensible i would look at various options plus or minus parts.
Cheers Jon,would only break though if the shell was going.Love the motor though and might still keep that as it could well end up in the new project,just dont ask what it is.
Here's the spec for peeps that don't have the mag.
ENGINE
Long studded EECIV 200 block
EECIV oil spray jets
Big winged sump
Standard stroke billet crank
8mm longer H section rods
Short J E Forged pistons
7-3-1 compression ratio
Group A spec oil pump
Big port head
Mechanical Reyland spec secret cams
Solid lifters
RS500 inlet plenum 4 greens, 4 greys managed by L8 with Pectel super 8
GT 35 Turbo
Reyland Turbo damper
TIAL 44mm external wastegate
2 WD exhaust manifold with Reyland external wastegate conversion – screamer pipe
Custom intercooler (4 Sierras Cosworth coolers together)
Quickshift stainless cone filter
Bailey Dump Valve
Group A Coil
Motorsport leads
Iridium 21 plugs
Mongoose downpipe into custom side exit exhaust
Full breather system
Aeromotive pump and filter into Reyland swirl pot
Group “a” engine mounts
TRANSMISSION
909 sport box with straight cut
Long 1st gear, direct top 5th
AP 6 paddle clutch
Quaife ATB front diff
SUSPENSION
Magnesium coil over Bilsteins on front, steel bodied on rear
Front alloy strutbrace
Adrenaline Rear strutbrace
Pollybushed front & rear end
BRAKES
AP 4 pots with 330 mm disc brakes front, 300mm rears with standard calipers
WHEELS & TYRES
8 x18 Group A fit OZ Motorsport Magnesium rims with Toyo R888 road legal track day tyres
Long studs, sleeved nuts
EXTERIOR
Front WRC spoiler
Rear Kevlar WRC spoiler
Morrette 4 Headlamp conversion
INTERIOR
Full Recaro leather
Autometer pillar mounted boost gauge
Piston gearknob
ENGINE
Big winged sump
Big port head
Solid lifters
GT 35 Turbo
Bailey Dump Valve
Group A Coil
Motorsport leads
Iridium 21 plugs
TRANSMISSION
AP 6 paddle clutch
SUSPENSION
BRAKES
WHEELS & TYRES
EXTERIOR
Front WRC spoiler
INTERIOR
Full Recaro leather
Piston gearknob
Originally Posted by allsteel
Just had carbon buckets fitted and picking the car up today so anyone wanting any pics of items please get in touch.
steerfromdarear
28
29-01-2016 06:14 PM
The Underdog
29
07-09-2015 09:49 PM
borboyous
22-08-2015 11:17 AM
