Did ford discontinue these?...............
http://cgi.ebay.co.uk/GGR880-Coswort...QQcmdZViewItem
If so, could replacements be sourced via SKF bearings
You can get pretty much any bearing + seal, by quoting the three numbers on it.
You need to be careful with wheel bearings to make sure they are classed as HIGH SPEED BEARINGS, a lot are not.
1 Post
yep - discontinued from ford as are the hubs,
but any local moto factors should eb able to sort you out a wheel bearing kit, bew innner and outers with new seals and grease, about £22. Q&H.
borboyous
22-08-2015 11:17 AM
