Breather system
Old 19-01-2007, 04:21 PM
auralisRS
auralisRS's Avatar
Default Breather system
Hi Guys
Has anyone else who has fitted an after market engine breather system suffered from blocking pipes, with moisture/white shite. This has happened twice now and subject to this oil is getting past turbo seals, causing embarrassing Vauxhall Cavalier tail smoke.
Old 19-01-2007, 05:18 PM
THE RADMAN
THE RADMAN's Avatar
nope,what size pipework are u using? presume its plumbed in correctly?
Old 19-01-2007, 05:21 PM
rapidcossie
rapidcossie's Avatar
have never heard of the pipes blocking?
Old 19-01-2007, 05:54 PM
Gatecrasher
Not welcome...
Gatecrasher's Avatar
dont mean to hijack your thread but i took my hoses off of my seperator and see this white gunk allmost had a fit at first wondering why it was there!! anyway my question is with the top air return pipe shitting out white crap back down the pipe to the trumpet side of the airfilter will this be ok recirculating back into the turbo/engine, the white shitty gunk that is?
Again sorry for the hijacking and no its never happend to me as iver only just got the car
Old 19-01-2007, 06:30 PM
tim10_10
tim10_10's Avatar
I had this on a rs turbo before, couldnt work out why it was doing it but I changed to a bailey breather and was ok after. What sort of breather are you using?
Old 19-01-2007, 06:43 PM
MONSTER
MONSTER's Avatar
Sounds like condensation to me, do you do many miles?
It could also be a sign of headgasket failure but its more than likely condensation.
Old 19-01-2007, 07:17 PM
redrsmk5
redrsmk5's Avatar
Does your car live outside like mine????? because i have this in mine on the top pipe of the mirror image tank.It is definitely condensation on mine as the car lives outside and has hardly moved in months. Fortunately i dont have a return to the air filter with the new setup.
Old 19-01-2007, 10:00 PM
auralisRS
auralisRS's Avatar
Yes it lives outside, and it is condensation, if the pipe runs are too long, then condensation does form and emulifies with the oil. It is common with a car that doesn't warm up much, and head gasket, (not that).
I have a can on the right turret, a breather from the original place under the inlet and an extra one from under the exhaust manifold. Both these feed the can. Then I have a pipe at the bottom of this can feeding a return to the original place. And on the top a vent to atmosphere. The whole thing woks like crap, ever since I put it on there, I have had oil feeding back from my turbo problems, after a while.
So the crank isn't venting, hence the oil return tries to find another way out, like through the turbo, even had oil spray coming out the dump valve.
Going to put the original back on, unless someone pursuades me otherwise.
Old 20-01-2007, 02:33 PM
redrsmk5
redrsmk5's Avatar
Doesnt sound good mate!
Im wondering why yours vents to atmosphere from the top? unless the cans are different from the mirror image tanks then im sure it should vent to atmosphere under the car?
You got any good tuners/garages near you that could help you out?
Old 23-01-2007, 11:37 AM
auralisRS
auralisRS's Avatar
it vents out the top, but runs from there under the car...
01-11-2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
17-10-2015 10:32 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
ST-170
04-09-2015 11:02 AM
Quick Reply: Breather system
