can be done without removing dash, still a pain in the arse though, i had the centre console out already, you need to remove the heater control panel & the pipes leading to this, remove the centre bracket etc, remove the 2 main heater box nuts & pull the heater box back enough to slide the matrix out.
to be fair its just as easy to remove the dash & not struggle!
My heater motor works fine but i dont have hardly any air coming out of the vents,all the pipes are on.Any ideas,ithink something is broken in the heater box........fookin nightmare to take out
