cosworth phase sensor
Old Jan 29, 2006 | 11:05 PM
Kam B's Avatar
Kam B
Default cosworth phase sensor
hi guys when these are on the last legs what does it make the car do? smoke n overfuel? i.e. black soot
Old Jan 30, 2006 | 12:01 AM
GARETH T's Avatar
GARETH T
idle strange/missfire
get hold of a scope and see if its working correctly
Old Jan 30, 2006 | 12:19 AM
jon@work's Avatar
jon@work
Coolant Temp Sensor Checking - info courtesy of Simon @ SECS
1) Ensure ignition is OFF.
2) Remove rear of ecu plug cover and insert plug back into ecu.
3) Turn ignition back on (do not start engine)
4) Check resistance between pins 29 and 11. Should be 800 to 5000 ohms (depends on temp). If outside this range, check sensor and/or wiring.
manuel boeckx
13
Oct 3, 2015 02:29 PM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Anutternutter
Aug 21, 2015 06:07 PM
muz
Aug 16, 2015 12:57 PM
Zoggon
Aug 10, 2015 10:39 AM
