replacing a water pump, escort coss
Old Jan 26, 2006 | 12:40 PM
statto's Avatar
statto
Default replacing a water pump, escort coss
just wondering firstly, how much is a water pump?
can anyone with a little experience around cars do this, any special tools needed, how do i go about doing it?
cheers for any help
Old Jan 26, 2006 | 07:37 PM
Dave McB's Avatar
Dave McB
1. about 60-150 depending on what one u buy (pattern or genuine ford)
2. allan keys, screwdriver, gasket sealer
3. its very easy, drain cooling system, take hoses off, undo allan bolts, take pump off, clean old gasket off block, put new one on (might as well get new thermostat at the same time, and fit it)
the key issue is preparation. Make sure the block is all clean and flat and it shouldnt leak
Old Jan 27, 2006 | 08:03 AM
statto's Avatar
statto
cool does the radiator or anything need to come off as it's very tight in there
Old Jan 27, 2006 | 04:35 PM
Dave Henshall's Avatar
Dave Henshall
i can do my thermostat housing an water pump with the rad in situ - u need a allen bit socket so you can get up close - mine doesnt have A/C though, nnot too sure if the ac rad is behind (in the way) or infornt of the main rad and intercooler though on a AC car.
Old Jan 27, 2006 | 11:26 PM
Azrael's Avatar
Azrael
In front of course
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
