Replacement fuel dial is reading wrong
Old Jul 20, 2004 | 10:18 AM
Kel - West Yorks's Avatar
Kel - West Yorks
Default Replacement fuel dial is reading wrong
Alright chaps,
I've fitted some new clocks to my S2 (the new ones have the fuel gauge to the left and the temp' to the right - my old ones were the other way round). Everything seems to be ok apart from the fuel gauge. It reads between half and a quarter when the tank is actually nearing empty (the computer backs this up), and when i stick £20's worth of juice in there, the needle moves up to nearly full.
Any ideas about what i can check for or what i might have done wrong?
Cheers!
Kel
Old Jul 20, 2004 | 10:45 AM
Dave Henshall's Avatar
Dave Henshall
sounds like you have pu the needle back on wrong. best bet would be to fill it to the brim, then remove the needle and refit it at the full mark with the ignitio on so that the pointer movement is assuming the full position.
Old Jul 20, 2004 | 10:51 AM
Kel - West Yorks
Ahhhh, i'll do that!
Kel
Old Jul 20, 2004 | 01:10 PM
Eagle's Avatar
Eagle
Super Moderator
you need to swap the wires around on the back of the clocks to get them to read correctly..;
your fuel guage is actually the water temp
Old Jul 20, 2004 | 01:15 PM
Kel - West Yorks
Bah, i should've guessed
j.hammond1
30
Oct 31, 2021 05:28 PM
Anutternutter
Aug 21, 2015 06:07 PM
Bailes1992
Aug 16, 2015 07:14 PM
RSMK4TURBO
Aug 13, 2015 08:06 AM
muffster
Aug 12, 2015 08:14 PM
