leeky water question? escort coss
hi
not 100% sure if it is the head gasket yet, as she's not running warm, is building up alot of pressure in the header tank and water wee bit foamy and dirty. water leek when stopped but unsure where it coming from, running down the front of the block and dripping from around the bottom pulley area, thinkin water pump or thermostat housing. any idea's? could it be the water pump or thermostat housing cracked? or is it the head gasket?
cheers
cheers
cossie do have a bit of a habbit of the head gasket leaking from the water jacket out down the side of the block under the turbo. maybe it has let go there and its running down round to the front....
just an idea,
if it is the pump, there shud be a little hole on the body of the pump its self, if it is the internal seal on the pump the water will be coming out of there
im probably wrong on all of the above, but it might be of some help lol
just an idea,
Aah good man, so if the water is dripping out of here when i stop the engine it's more than likely the water pump thats shat itself. does the car need to be run warm first? and would this cause her to foam the water up a bit?
cheers
cheers
