ABS pump on Escort cos
Old Jan 20, 2006 | 12:03 AM
gog's Avatar
gog
Default ABS pump on Escort cos
Is the ABS pump supposed to be active when the ignition is switched off?
Doesn't seem right and could account for my flat battery problem!!
Old Jan 20, 2006 | 12:08 AM
Azrael's Avatar
Azrael
It works on 1st and 2nd ignition position.
Old Jan 20, 2006 | 10:26 AM
cocaina_xr2i's Avatar
cocaina_xr2i
wrench it all
yes mate it should be off when the ignition switch is on the off position and mostly when you car is locked for the night so yeah it may be the cause of your flat battery
Old Jan 20, 2006 | 10:43 AM
Dave Henshall's Avatar
Dave Henshall
i found that the realays inteh bot of the car had quite bad arc damage to the contatcs , this maybe whats happened and the contacts have welded shut, keepin gthe power onto the pump all teh time
Vincereese
Jun 1, 2023 09:14 AM
Carlbacciochi
24
Jun 30, 2016 04:31 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
