Fiesta MkIII N reg - stalls
Old 19-01-2006, 08:34 AM
JarvisD
JarvisD's Avatar
Default Fiesta MkIII N reg - stalls
Engine stalls intermittently for the last 6 months, sometimes after its been running in slow traffic, other times after its been at higher revs and the engines been warm. Had a service, electrics all look OK, air filter changed etc. Have also used a carburettor spray - removed air filter while engine running and sprayed in - seemed to help, but not completely. The tick over is set to 750, but drops to aroung 450 / 500 then either gradually comes back up or drops a bit more and stalls.
Anyone had similar and managed to sort it? DJ
Old 19-01-2006, 02:29 PM
AGAR-COSWORTH
Redumbdancy
AGAR-COSWORTH's Avatar
What air filter are you using - standard or bolt on kit?
Old 19-01-2006, 05:16 PM
HORNETS7
HORNETS7's Avatar
needs setting up on a rolling road imo
it sounds like a fuelling problem or maybe a air leak
bobsworth
77
24-03-2016 09:30 PM
07-10-2015 12:56 PM
gcfcos
59
06-10-2015 05:04 PM
gingeRS
17
02-10-2015 09:42 AM
Steve Escos
01-10-2015 06:57 AM
Quick Reply: Fiesta MkIII N reg - stalls
