rs turbo piston rings
Old Jan 18, 2006 | 07:28 PM
dmcruley's Avatar
dmcruley
Default rs turbo piston rings
Are the genuine ford piston rings for an escort rs turbo the same as the piston rings for the fiesta rs turbo (will they fit).
And is it usefull top replace the piston rings with STANDARD SIZED ones when rebuilding a fiesta rs turbo engine (don't know the exact milage)
Old Jan 19, 2006 | 07:10 PM
sexr3i's Avatar
sexr3i
isn't it
the size (std or not) will be stamped on the top face of the old rings and probably the piston too if they're oversized.
frst and erst should be the same as internally it's still a cvh with same bores etc so dont see why they wnt work?
Old Jan 20, 2006 | 08:22 PM
JesseT's Avatar
JesseT
at least the N/A efi engines had different rings to the MFI engines.
Rstar_man
143
Jul 20, 2020 11:16 PM
rsturbo27
Sep 1, 2015 09:54 PM
KW-rscos
11
Aug 31, 2015 01:51 PM
Escortdriver1
Aug 31, 2015 11:19 AM
Adam-M
22
Aug 10, 2015 10:46 AM
