removing the oil pipe????????/
Old Jan 17, 2006 | 05:42 PM
barry0777's Avatar
barry0777
Default removing the oil pipe????????/
hi there i ask for your help awhile back and know decied to have a go at fixing the prob the prob was the turbo return pipe on my s2 rsturbo was flowing back up the pipe and it seams to be that the pipe was not letting all the oil back in to the sump,so i was wondering if any of you have modifyed this pipe in the sump it self.so iwas wondering if id should remove the pipe altogether just needing to know if any of you guys have done this or is there any other alternitive.as it only going back in to the sump and cant teally see the probs if i did this?????????/any help pls thanks ???
Old Jan 17, 2006 | 06:01 PM
Moonie's Avatar
Moonie
Strange!
How do you mean remove the pipe all together?
The return pipe needs to be there and to allow the flow of oil through the turbo and return back to the sump.
Old Jan 17, 2006 | 06:10 PM
barry0777's Avatar
barry0777
sorry my bad discription no im keeping the return pipe that gose outside the sump it the one inside the sump its gets smaller around 11mm compared to the one on the out side witch is 15mm iwas gonna cut it off so the oil can get in to the sump quicker,is that better???????????????????
Old Jan 18, 2006 | 08:10 AM
barry0777's Avatar
barry0777
anyone whos done this??????????anyone?????
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
kevin36
Sep 2, 2015 06:24 PM
