Mondeo leaking coolant even AFTER pressure test
Old Jan 16, 2006 | 10:37 AM
yoshi's Avatar
yoshi
Default Mondeo leaking coolant even AFTER pressure test
My Mondeo 1995/2.0i GHIA is leaking some coolant. This has occured after I had the cooling system rebuilt - new pump, new thermostat, new radiator. I've also had both pipes from the radiator replaced which cool the gearbox etc. so they are new also.
I've had it pressure tested and it doesn't leak under the test.
If I take it for a short drive e.g.15 miles, it doesn't leak coolant.
However, when I take it for a long drive and park it in the driveway later, I notice a puddle of coolant being deposited.
It basically randomly spits some coolant when it feels like it.
This equates to 400-500ml per week. My mechanic has no idea what it is.
Ideas?
Picture below shows where the leak is, there is a rubber pipe in that area and we've put 2 clips on it to make sure it's 100%. Still leaks unpredictably.
Old Jan 16, 2006 | 11:00 AM
cocaina_xr2i's Avatar
cocaina_xr2i
wrench it all
chek the hose from the water pump to the radiator my mates 1 what doing it exactly the same way and was that hose was tosted so it could be that
Old Jan 16, 2006 | 11:10 AM
yoshi's Avatar
yoshi
Thanks for the tip.
Can I ask how the hose failed? The pressure test indicates it's OK.
Or is it when the hose gets hot it expands too much?
I assume your mate has a Mondeo as well...
Old Jan 16, 2006 | 03:03 PM
SafeChav's Avatar
SafeChav
Sounds like a get it on the ramp and wait til it leaks so you can find where its comin from
Old Jan 16, 2006 | 09:29 PM
cocaina_xr2i
wrench it all
yeah sure mate the hose failed cuz when it got hot it had like little hole almost like the nylon material in the was leading it out if you know what I mean but yeah I mean the presure test on his was fine
Old Jan 16, 2006 | 10:30 PM
DazC's Avatar
DazC
How long did you have the pressure tester on it?
Old Jan 16, 2006 | 10:36 PM
cocaina_xr2i
wrench it all
who me?[/quote]
Old Jan 17, 2006 | 08:39 PM
yoshi's Avatar
yoshi
We did the pressure test for around 1-2 minutes. It didn't leak.
We had it on the ramp, no drips.
Somebody suggested this :
'I had to do a head gasket on a Mondeo a feew years back. It was the pipe exactly above where your leak is coming from. It was a metal pipe about 15mm in diameter. It had rusted through and I remember when I bought the new pipe from Ford the parts guy said these go all the time. It may be that its just when it is full upto pressure that it leaks as steam. Not that noticible on a short journey.
What do you guys think it is?
Old Jan 17, 2006 | 08:50 PM
cocaina_xr2i
wrench it all
could be one option mate
Old Jan 17, 2006 | 08:57 PM
DazC's Avatar
DazC
I personally would leave the pressure tester on for 15-20 minutes with slightly excessive pressure in the system and watch it.
Old Jan 17, 2006 | 09:36 PM
dave green's Avatar
dave green
As Daz c said
Botts
Sep 22, 2015 02:04 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
Brickhouse
Sep 20, 2015 11:47 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
