4x4 sierra&escort gearboxes.
Old Jan 12, 2006 | 10:59 AM
nik t's Avatar
nik t
Default 4x4 sierra&escort gearboxes.
Can anyone tell me if an escort 4x4 box goes straight in a sierra 4x4?.
Have been told its not that simple. Cheers.
Old Jan 12, 2006 | 12:22 PM
Azrael's Avatar
Azrael
I don't see any differences between Escort Cossie and Sierra Cossie 4x4 gearbox.
Old Jan 12, 2006 | 02:48 PM
GAZ345's Avatar
GAZ345
escort box will go into sierra,but early sierra 4x4's box had a diffrent rubber propshaft joint, but it will swap over, also if i remember right the reversing light switch is different again straight swap just to add it is a cossie sierra 4x4 your talking about
Old Jan 12, 2006 | 06:44 PM
silky16v's Avatar
silky16v
Get on That!
should be straight swap i had to change reverse light switch but that was it.
Also if i right in thinking the Escort MT75 gearbox had a revised syncro on 1st-2nd gear
Old Jan 12, 2006 | 07:38 PM
nik t's Avatar
nik t
Yes is a cossie 4x4.
Only asking because i had a very clean low mile one but who i thought was a good friend told me it wouldn't fit,and swaped me for a sierra one witch looks like its done 200k.
Ever get the feeling your've been had!
Old Jan 14, 2006 | 09:00 AM
2ndGear's Avatar
2ndGear
Default Check the output shaft and flange
on the back of the box its not the rubber joint thats different there are two types of output shaft and one is longer that the other. So this might cause you some trouble.
Old Jan 14, 2006 | 12:48 PM
bige's Avatar
bige
as long as it is an MT75 4X4 its direkt fitt too engine. you can even put a MT 75 on it as an 2wd - from Scorpio .
Old Jan 14, 2006 | 01:19 PM
RickRS1976's Avatar
RickRS1976
id say you mate has done you out of a good box that you could of used, it would of fitted just swap a few simple parts that can come off the old one. ring him and get it back m8!
Old Jan 14, 2006 | 08:25 PM
nik t's Avatar
nik t
Not that simple m8.
He told me he has already sold it on!
Old Jan 14, 2006 | 08:56 PM
RickRS1976's Avatar
RickRS1976
not the sort of mate you want nik t , i bet he made a mint out of you selling that on.
id say recon yours before you fit it!
Old Jan 14, 2006 | 09:03 PM
nik t's Avatar
nik t
think your right son,some u win,some u lose.
Old Jan 15, 2006 | 02:31 AM
RickRS1976's Avatar
RickRS1976
I see your in Essex? where abouts, you may be local.
Old Jan 15, 2006 | 09:38 AM
nik t's Avatar
nik t
Chadwell heath son.
Old Jan 15, 2006 | 02:18 PM
RickRS1976's Avatar
RickRS1976
cool not far from me
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
