compression ratio
Old Jan 10, 2006 | 04:01 PM
cossyhell's Avatar
cossyhell
Default compression ratio
hi if any one can help that will be top
ive got 205 block which i want to put 1mm oversize 4x4 new piston which i have already in, i will be using a standard head normal group a head gasket etc etc.
i want to run t3 300bhp @21psi or t34 330bhp @24psi
do i need to tell the machine shop to lower the comp on the pistons or will they be fine or if someone knows what comp ratio to use then i can tell the machine, if you get where im going from.
i know 1mm pistons arnt a good idear for big power i just need to put an engine to gether while i finish my big power engine.
many thanks steve
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
