ECU Prob
Old Jan 9, 2006 | 07:06 PM
Focused's Avatar
Focused
Default ECU Prob
Any one help I need the info on which pin does what on two ecus.
One is from a xr3i efi and the other is a 130bhp 3i mk4.
Doind a zetec conversion and having probs with wiring . Only got 8 ires to sort lamda etc. Do i need to run lamda as not using cat? I asume i do as using the standerd ecu.
thanks
Old Jan 10, 2006 | 11:41 AM
Focused's Avatar
Focused
up
Old Jan 10, 2006 | 05:10 PM
sailorbob's Avatar
sailorbob
You need to give people a bit more to go on, what are the two ecu's?
Old Jan 10, 2006 | 11:06 PM
SafeChav's Avatar
SafeChav
from what you have said they sound like the same ECU's an EFI XR3i is the MK4?????
as above a bit more info is required, then i can probably help you
Old Jan 11, 2006 | 05:12 PM
Focused's Avatar
Focused
Soz a bit of a miss type
One is a 1990 xr3i efi
The other is a 130ps xr3i mk5.
What it is i am putting a zetec in the mk4. Got the engine loom but not main loom as car was nicked before i got it out.
The prob is there is a 8 pin multi plug on the engine loom that joins main loom. Wondered what each pin does on ecu. That way i may be able to use some of the standard wires in the mk4 instead of having seperate relays etc. Any help?
Old Jan 12, 2006 | 02:30 AM
SafeChav's Avatar
SafeChav
Hmmmmm, that could be tricky, what would be very helpful is firstly the wire colours, and possibly a picture of the loom, so i can see what is on the loom to make tracing the wires a bit easier.
What type of engine is it (MK5's having numerous different engines) and whats the ECU code aswell?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
gcfcos
59
Oct 6, 2015 05:04 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
