Cossie Powersteering?
Old Jul 16, 2004 | 02:47 PM
RSrussell's Avatar
RSrussell
Default Cossie Powersteering?
Are the pumps know to fail?
Mine has been off the road for 8 months, i've just started it and took it around the block, it has lost some fluid and it sounds noisy as fook.
Does it just need constant lubrication and it will go away, or is the assembly knackered?
Old Jul 16, 2004 | 11:02 PM
Gerry Mac's Avatar
Gerry Mac
MIGHT SOUND SILLY BUT IF LOW IN FLUID IT DOES GET NOISY OR CHECK THE PIPE ISNT BLOCKED.
Old Jul 17, 2004 | 02:11 PM
RSrussell's Avatar
RSrussell
I was hoping that is the case, we'll see. cheers
Old Jul 17, 2004 | 05:52 PM
richm's Avatar
richm
if it is fooked, they are the same as MK5 Escort pumps - you may just need to swap over the inlet pipe fitting
Old Jul 17, 2004 | 06:53 PM
RSrussell's Avatar
RSrussell
thanks rich
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
