Mk3 escort wiring
Old Jan 3, 2006 | 06:03 PM
street's Avatar
street
Default Mk3 escort wiring
Hello!
Can anyone tell me which colour wires operate which warning lights on the mk3 Escort dash?
I cant find my manual ANYWHERE and i really need to sort out the wiring by the weekend
Im not using a standard escort dash so any refference to the numbers on the plugs or refference to the circuit on the back of the dash is no good!
Just which colour wire does what would be ace
Thanks loads for any help!
Old Jan 3, 2006 | 11:13 PM
SafeChav's Avatar
SafeChav
Which warning lights? For the auxiliary warning module?
I'm familair with the MK3 wiring
Old Jan 4, 2006 | 04:39 PM
street's Avatar
street
Yep, its the indicators, handbrake light, oil light, water light..... think thats all of them?
Cheers!
Old Jan 4, 2006 | 05:58 PM
Moondust_crust's Avatar
Moondust_crust
familair? he is like the king of car electrics mate, if he cant sort ya nobody can!
Old Jan 5, 2006 | 12:32 AM
SafeChav's Avatar
SafeChav
Speechless......really don't know what to say to that Thanks is a start i guess!! Have you been reading all my posts or something?
Cheers!
The auxiliary warning module has 5 lights, Brake pad wear, washer bottle level, oil level, coolant level and that godly petrol light.
Duno what wires u need to know so fuck it i'll list them all (numbered as they appear on the auxiliary warning module plug
1 - Grey/Black (joins into the common illumination feed)
2 - NC
3 - NC
4 - NC
5 - Brown/Yellow (RH Brake Pad Sender)
6 - Brown/Yellow (LH Brake Pad Sender)
7 - Brown/Green (Fuel Sender)
8 - Brown/White (Washer Fluid Sender)
9 - Brown/Red (Coolant Sender)
10 - Brown (Electronic Dipstick)
11 - Brown/Black (Electronic Dipstick)
12 - Brown/Black (Low Oil Warning Lamp In Instrument Cluster)
13 - Brown/Red (Low Coolant Warning Lamp In Instrument Cluster)
14 - Brown/White (Low Washer Fluid Warning Lamp In Instrument Cluster)
15 - Brown/Green (Low Fuel Warning Lamp In Instrument Cluster)
16 - Brown Yellow (Low Brake Pad Warning Lamp In Instrument Cluster)
17 - Black/Red (Positive Feed To Warning Lamps) (12,13,14,15,16 are all switched Negative Outputs)
18 - Black/Yellow (Switched Igniton Feed)
19 - NC
20 - (Permenant 12v) NOTE: i have seen modules that dont use a permenant 12v however?????????
21 - NC
22 - Common Negative/Earth
NOTE: all the sensors with the exception of the Electronic Dipstick only have 1 wire to the module, and the other side of the sensors all connect to Common Negative/Earth
Old Jan 5, 2006 | 06:29 AM
Moondust_crust
told ya!
Old Jan 5, 2006 | 01:49 PM
SafeChav's Avatar
SafeChav
told ya!
Credit where its due though, i had to whip the old manual out and trace the wires/colours etc im not that good (i wish)
Old Jan 5, 2006 | 06:26 PM
street's Avatar
street
Mate that is brilliant!!!!
Thanks loads for taking the time to help me out, really appreciated
You have good karma coming your way dude
Old May 17, 2024 | 05:42 AM
frodmyster's Avatar
frodmyster
Sorry to bump this thread but could someone please tell me what colour wire is for the hazard lights indicator on the dash clocks please. I'm having problems with my mk3 escort wiring
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
muz
Aug 16, 2015 12:57 PM
