cosworth timing
Old Dec 29, 2005 | 05:59 PM
s1 2oobhp's Avatar
s1 2oobhp
Default cosworth timing
just had head gasket done an when i go 2 3000rpm it backfires looks like its 1 tooth out on the dissy how easy is it 2 move 1 tooth as cam timing fine cheers
Old Dec 29, 2005 | 06:18 PM
davidreader5's Avatar
davidreader5
S1 200,
As your say post says cosworth timing i assume it is on a yb cosworth
engine, With the dizzy it is easy enough, just check the cams align &
the engine is @ TDC on no1 cyl comp stroke, then if you then remove the distributor it is a bit trial and error, hold the dizzy so the spring clip of the cap,points to the engine block and the rotor points away from engine
then as you install the dizzy the rotor arm will turn ,if you look on the
body of the distributor you will see a scribed mark when installed the rotor
arm should align with the mark, indicating cylinder no1 in relation to the cap. SO YOU HAVE to judge it, needs to be correct for the phase timing.
DAVE R.
Old Dec 29, 2005 | 06:36 PM
s1 2oobhp's Avatar
s1 2oobhp
sorry mate its my 4x4 cosworth yb
Old Dec 29, 2005 | 06:49 PM
CosRush's Avatar
CosRush
Have you looked at my post in the Technical essays section under 'cam timing' to be sure it is timed incorrectly???
Old Dec 29, 2005 | 07:20 PM
s1 2oobhp's Avatar
s1 2oobhp
not a gold member
Old Dec 29, 2005 | 07:21 PM
CosRush's Avatar
CosRush
ahhhh
Old Dec 29, 2005 | 09:10 PM
s1 2oobhp's Avatar
s1 2oobhp
all sorted cheers lads
Old Dec 30, 2005 | 10:44 AM
CosRush's Avatar
CosRush
Excellent
Aug 14, 2015 07:29 AM
