Idling all over the place.
Old Dec 29, 2005 | 10:33 AM
Modder_J's Avatar
Modder_J
Default Idling all over the place.
Arg, my S2 wont idle properly.
It used to idle fine when starting on cold, but a few minutes of touching the throttle (to reverse out of the drive) the revs would drop to around 400-ish and stay that way until the engine had started to warm up.
So I sat the car on the drive, rev'd it slightly and waited for the revs to drop before adjusting the revs so that it was comfortable.
Started the car up in the evening (from cold) and it was idling fine.
... but now when its warm/hot (good running temp) it idles between 1000 and 1400 rpm
I had a quick look through the newest Fast Ford before coming on here, and read that their staff S2 has had almost the exact same problems as I have had so far with mine.
With their idle problems, I think it came down to the chip on the ECU.
I also read in a previous Fast Ford that the ECU I have in my S2 can cause running issues.
Could swapping the ECU be the answer ?
CheeRS
Old Dec 29, 2005 | 06:01 PM
davidreader5's Avatar
davidreader5
HI,
Could be so many things, but check the cold start function ie, the
cold start valve is working , if not check that power is going to it from
cold, if no power check the thermo time switch in the inlet manifold
(underneath , it is brown ) also the wiring to the cold start valve has no breaks, the thermo switch controls the power to the cold start valve
but for only a short time, the fuel ecu controls warm up enrichment,
starting enrichment, acceleration & full load enrichment etc, through the fuel pressure actuator,
also check you have no air leaks on any of the hoses to and from the turbo to engine inlet, ( if large air leak it wont idle RS turbo escort)
and check the auxillary air device is working,(open & closing)open when
cold,
DAVE R.
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
