mk 6 escort help please!!!!
Old Dec 21, 2005 | 08:12 PM
artley's Avatar
artley
Default mk 6 escort help please!!!!
need some help on my dads mark 6 escort 1800 ghia
problems
- The other day the interior lights would not switch off at all
- The alarm doesnt always arm from the drivers door(could the door lock electric bit for the alarm be nakered?)
- The washer motor for the front makes the noise plenty of water in it,no blockage in the pipes but doesnt work, and whats the wire coming off the actual washer jets?
- The brake pedal makes the Fog light on the button come on and the heated screen, isit a bad earth and any ideas where to look? doesn't always do it either!!
checked the engine bay for bad earths on battery and all chassis leads etc but seemed ok can anyone help? htanks james
Old Dec 22, 2005 | 06:29 AM
filthyrichie's Avatar
filthyrichie
drivers door barrel switch faulty ..part about 15 quid
wire on jets is heated jets remove pump and remove seal you will find the seal is covered in gooo either remove it or put a hole through the mesh part to clear it
open boot lid and check the contact pins clean as req...then look at the point where the boot is fixed to the car and spray the pins with wd40 and tap left and right a few times with small hammer this is the earth point for all rear tailgate electrics
benw456
Sep 16, 2015 05:27 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
