4wd conversion, which transmission tunnel???
Old Dec 18, 2005 | 01:24 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Default 4wd conversion, which transmission tunnel???
I'm currently pricing 4wd for my puma once its sprayed.
Sorted out rear suspension problems and transverse mounted 4wd issues.
Now need to price up longitudinal mounting for either cossie or zetec turbo!
obviously i need a much bigger tunnel at the front for the mt75 gearbox and slightly deeper tunnel rear wards to clear prop.
Can i cut a tunnel out of a sierra shell to have welded in??
if so do I need to get a specific cossie one or will a normal RWD or xr4x4 one do???
Thanks
Warren
Old Dec 18, 2005 | 10:17 AM
NUTS RuS's Avatar
NUTS RuS
Nothing will be a straight forward fit so I guess you will have to fabricate a special.
Old Dec 18, 2005 | 10:27 AM
foreigneRS's Avatar
foreigneRS
Testing the future
if you take one from a sieraa, it must be from a 4x4 one, although not necessarily cosworth.
Old Dec 18, 2005 | 10:45 AM
Psycho Warren
Carbon Crazy
excellant!! so there no need to commit sacrilage and hack a 4x4 cossie when I can slay a £100 donor xr4x4 instead!!!!
Old Dec 18, 2005 | 01:53 PM
TWoods's Avatar
TWoods
Hi i thought this might be some usefull to you in some way, a little while ago i had an engine conversion on my fiesta they guys who carried it out had a 4x4 2001 fiesta, i recall them saying they used a mitsubishi evo 4 running gear which fitted a lot easier than the other methods they considered. The tunnel / housing they just cut and welded in metal panels through the spaceframe instead of finding a donar.
Old Dec 18, 2005 | 07:25 PM
Psycho Warren
Carbon Crazy
Who were they?
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
