Cosworth fuel line
Old Dec 16, 2005 | 09:32 AM
MalteseFalcon's Avatar
MalteseFalcon
Default Cosworth fuel line
For how much bhp is good a standard Sierra Sapphire Cosworth fuel line? If this needs to be uprated than what size do I have to make? Also are the banjos from the pump to the fuel filter and from the fuel filter to the main line restrictive? The Sierra is 500bhp+ . Thanks for the help
Old Dec 16, 2005 | 03:38 PM
DaveEscos's Avatar
DaveEscos
Std is fine, but run -6 from the pump all the way to the fuel rail / reg
Old Dec 16, 2005 | 05:18 PM
MalteseFalcon
Thanks 4 d help but what you mean by but run-6?
Old Dec 16, 2005 | 08:09 PM
Fastmaul's Avatar
Fastmaul
K155MYRS
Come on God, don't you know?? -6?? is the size
Old Dec 18, 2005 | 12:01 PM
MalteseFalcon
hey pal we speak another type of language here and I never heared about this -6!!! Dont lough but here seems that no one knows about this -6 type! maybe they got another name fo it or something. So would you be so kind and explain to me in detail?
Old Dec 18, 2005 | 05:22 PM
jon@work's Avatar
jon@work
Old Dec 20, 2005 | 06:22 PM
MalteseFalcon
ok i got it . youre so much help thanks pal!!!!
I know about thread sizes but we use a slight different pronaucation for them thats why I was confused about that but now I cleared everything!
So you think this is allright for 500bhp ehh! The thing about the banjos IM not sure couse i think they re a littlle bit restrictive.
Old Dec 22, 2005 | 10:05 AM
DaveEscos's Avatar
DaveEscos
use proper FORGED hydraulic fittings for the fuel hose
see here
http://www.thinkauto.com/acatalog/Pr...ttings_46.html
Old Dec 25, 2005 | 06:23 PM
Fiecos Dan's Avatar
Fiecos Dan
std being 15mm into pump, and 8mm bein from pump to reg, and 8mm return.
i believe std is good for 550+ bhp.
Old Dec 26, 2005 | 06:53 PM
MalteseFalcon
Well thanks mates, I can leave everything as it is!!!
Old Dec 26, 2005 | 08:53 PM
Fiecos Dan's Avatar
Fiecos Dan
best way is flow check your system at 3 bar, and as if it can flow wot you need, it will be ok.
Wot power are you goin for?
3doorcozmess
Aug 21, 2015 11:17 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Aug 14, 2015 07:29 AM
RSMK4TURBO
Aug 13, 2015 08:06 AM
muffster
Aug 12, 2015 08:14 PM
