Fuel system to 550bhp
Old Dec 6, 2005 | 08:12 PM
sirmark's Avatar
sirmark
Default Fuel system to 550bhp
Hi,
How do I make the fuel system in a way that it delivers fuel enough to 550bhp? Would it be enough with only one fuel pump or does it require that you mount two parallel pumps. I could really use some detailed information about this as I plan to get started asap.
I also welcome other solutions or pros/cons
I would prefer answers from people with practical experience with this particular issue.
The car we’re talking about is an Escort Cosworth from 1993.
Mark
Old Dec 7, 2005 | 07:48 PM
wimwerf's Avatar
wimwerf
there are some pumps around which can deliver enough fuel for such bhp...dont know the name
Old Dec 7, 2005 | 08:25 PM
DazC's Avatar
DazC
Bosch make a pump which fits into the tank. I am not sure if this will flow for 550 bhp but if it won't I think the only way to get round it is use this pump to lift the fuel into a swirl/collector pot then 2 pumps to supply the fuel down -6 fuel lines. You will probably also need to uprate the pump wiring as well.
You will need to confirm but I think the Bosch in tank pump is 0 580 254 003.
Old Dec 11, 2005 | 09:25 PM
Escos Jam's Avatar
Escos Jam
Hi there mate. i currently have 3 pumps on my escort. An internal lift pump in the tank supplying a swirl pot and 2 external pumps supplying the fuel system.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
A.t.p
Sep 29, 2015 05:04 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
ST-170
Sep 4, 2015 11:02 AM
