Cosworth High Idle
Old Dec 5, 2005 | 11:43 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Default Cosworth High Idle
Hi all,
Recently my Cossie has been idling fast, and a bit reluctant with the throttle 'just' open.
I've replaced the plugs, leads, dizzy cap, distributor (cos I broke the other one), and I've just replaced the ISCV and TPS. It's still idling at 1500 and still sounds hesitant (like not firing) with the throttle 'just open', but not as much as it was before.
Cold idle just starts at 1k and winds up a bit, but after that, it'll idle at 1500. And, because it's idling fast, there's not a great deal of engine braking, so I'm having to brake harder and longer than I normally would.
Last night, it wound itself up to 2k, disconnecting the ISCV (as per a similar problems I've read about) has no effect - still idles at 2k.
From what I've gathered, the only remaining things to replace/check are: ECT, vacuum hoses, the MAP sensor, inlet manifold gasket, throttle body gasket. Which of these is the most likely culprit? The base idle has been mentioned, but I've never had to touch it - it used to be perfect!
When I had the throttle body off to replace the TPS, I cleaned it out with carb cleaner...would that make a difference?
Answers on a postcard, please...
Old Dec 5, 2005 | 12:13 PM
boost mad's Avatar
boost mad
i would check for air leaks mate. that shud be the first step and also a free one
Old Dec 5, 2005 | 07:39 PM
Fiecos Dan's Avatar
Fiecos Dan
yeah airleak, normally goin to fuel regulator, or throttle stickin slightly open.
Old Dec 6, 2005 | 07:21 AM
CosRush's Avatar
CosRush
Yeah agree with above, sounds like an airleak to me.
Get yourself a can of 'East start' and spray it around any areas you think it might be leaking from.
If you spray it on the leak the revs will go up further.........
Old Dec 6, 2005 | 01:00 PM
cozmeister's Avatar
cozmeister
More boost Igor!
East start Not Wd40 or Damp start?
Thanks for the input guys, I'll have a go Saturday morning. Will post the results here.
Apart from a massive fuel bill, is there any other side effects that I should be worried about?
Old Dec 6, 2005 | 01:35 PM
CosRush's Avatar
CosRush
Sorry..
EASY START
Its very probably called something different now like Damp Start, same stuff, just the can ive got in my garage is about 10 years old...
Old Dec 6, 2005 | 04:36 PM
Dave Henshall's Avatar
Dave Henshall
easy start, the con rod bender
better use something like some solvent degreaser,
Old Dec 6, 2005 | 05:24 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
You say you changed the TPS, I assume you set it up properly, not just a case of fit and forget
I would check for leaks as said above (carb cleaner has been mentionned before ).
You may want to add dodgy wiring to your list, new sensors are no good if you've got a break in your loom, and we know they are getting old.
If it's a 4x4 sapph, worth cleaning the three connectors on the bulkhead with contact cleaner while you're there.
Good luck
Old Dec 6, 2005 | 06:40 PM
CosRush's Avatar
CosRush
You're not seriously suggesting it'll bend a conrod at idle
Old Dec 6, 2005 | 06:41 PM
CosRush's Avatar
CosRush
Also, do a check for any ECU codes........
Old Dec 6, 2005 | 07:18 PM
Fiecos Dan's Avatar
Fiecos Dan
Best way to test for air leaks is to pressure test the whole system,
i test mine to 40 psi,
i bong the turbo air filter pipe, and then pressure test the lot usin a compresser and a regular.
Also check the TPS is correctly position'd
Old Dec 8, 2005 | 03:19 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Good luck
Fit and forget...lol
Fitted as per the Ford Sierra/Escort Cosworth Workshop Manual. It's a 2wd Sapph - the TPS that was on it was black, and didn't look particularly old; the replacement is red (both PF01). Both had a resistance all the way around, except at what I'm guessing was the 'closed' position.
Old Dec 8, 2005 | 05:12 PM
Chris Honeywell's Avatar
Chris Honeywell
Really does sound like an air leak m8
I had exact same thing on mine a year or so back was the gasket on the plenum was leaking a the bottom nearest the bulkhead
Old Dec 10, 2005 | 10:57 AM
rsnissan's Avatar
rsnissan
i had one of the throttle brackets bolts come out (on the plenum cover) and the thing idled at 2k so i'd deffo go with the air leak option!
Old Jan 14, 2006 | 08:18 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Had it looked at yesterday, and it turns out that the inlet manifold gasket's gone, so one's on order.
Will it do much damage driving it around in the mean time?
Old Jan 14, 2006 | 10:42 PM
Fiecos Dan's Avatar
Fiecos Dan
i wouldn't put your foot down, as fueling might be out due to leak.
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
muffster
13
Sep 3, 2015 09:40 PM
Sheepdisease
Aug 30, 2015 09:11 PM
Adam-M
Aug 26, 2015 05:53 PM
Aug 14, 2015 07:29 AM
