escos not turning over/starting
Old Jul 12, 2004 | 10:46 AM
Firestarter's Avatar
Firestarter
Default escos not turning over/starting
Going down the road (30mph), car just stopped firing & died, pulled over, dash lights on, everything working, but starter motor won't turn over (volt meter doesn't move when cranked).
Had a look for the problem, couldn't find anything obvious, tried it quite a few times, only once did it turn over for a few seconds, but did not start.
btw, there's a 20A fuse (connected to a relay-3 of them) on the ABS (which has never worked) ecu thing in the boot which has blown & blew again as soon as I put the ignition on, don't know whether it has anything to do with it??
Had another look this morning, still the same, but actually turned over once & started, but 5 seconds later died again (this was with the abs fuse blown).
Anyone help??????
Cheers, Nik
Old Jul 14, 2004 | 07:42 PM
Firestarter
Self helped!!
Fuse box resolder cured the problem............... phew!!
There must have been a solder shortage when these were made!
Old Jul 14, 2004 | 07:54 PM
AJ Escos's Avatar
AJ Escos
escos fuseboxes are well known for being dodgy m8
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
gcfcos
59
Oct 6, 2015 05:04 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
