smoking on idle
Old Nov 30, 2005 | 02:22 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default smoking on idle
my zetec is smoking on idle (blue) how do u tell if its the turbo or ring or valve stems???????????????????????????
Old Nov 30, 2005 | 08:55 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
ello
Old Dec 2, 2005 | 08:19 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
DOSE ANY 1 KNOW ???CAN U TELL??? OR IS IT JUST A CASE OF REPLACING STUFF UNTILL IT STOPS??
ANY HEALP WLD B GREAT
Old Dec 2, 2005 | 08:54 PM
Chrissy_bwoy's Avatar
Chrissy_bwoy
was turbo on mine
Old Dec 2, 2005 | 09:38 PM
sailorbob's Avatar
sailorbob
To see if it's the turbo, take the outlet pipe off the compressor housing and if the seals have gone you'll see oil (varying from small streaks to a liberal coating everywhere depending on how bad it is) in the housing and the outlet pipe.
To see if the rings have had it you usually do compression test, record the readimgs, pour a tablespoonful of oil down the spark plug holes, repeat the compression test and if the compression readings are substantially higher then the rings are shot.
Old Dec 3, 2005 | 07:48 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
thanks alot i took the inlet pipe of to t/b there was no oil there so i will try compression test thanks alot ,tommy
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fudgey
21
Sep 30, 2015 06:19 PM
A.t.p
Sep 29, 2015 05:04 PM
